It is currently Sun Aug 02, 2026 12:53 am
PostPosted: Mon Jul 01, 2019 12:16 pm
Hi everybody, I'm new to the forum :)
I have a 1998 Hobie 16 (Europe) with an old style mainsheet traveler swivel cam cleat. And with an old style baseplate on the rear beam. I think it's from a company called "Northfix" Looks like this:
However, I need to replace it and I'd like to use today's standard Harken cleat (with bullseye). I figured it uses a different type of baseplate on the beam.
Now my question:
Can I just replace the old baseplate by the new one? Does anybody know if the holes are the same or do I have to drill new ones??
Obviously, worst case would be when the holes wouldn't fit by a few millimeters :?
Thank you so much in advance!
Polardorsch
https://www.hobie-cat.at
PostPosted: Mon Jul 01, 2019 1:08 pm
No idea on the hole placement... doubt they are the same.
PostPosted: Tue Jul 02, 2019 1:01 am
Do you know If the Base Plate is a Hobie specific part?
Can't find it in the Harken catalog..
PostPosted: Tue Jul 02, 2019 7:57 am
Yes.
1162 MOUNTING PLATE W/HARDWARE
PostPosted: Fri Aug 09, 2019 10:37 am
I posted a few years ago about overhauling some of my cleats and trying to standardize on that Harken Cammatic 150, which (on my 2000 boat) is used everywhere except the main traveler, where I had a Holt-Allen 76. According to that thread the center spacing is the same but the bolts needed to be longer.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Tue May 31, 2022 7:39 am
So do any of the screws in the swivel base go into the rear cross beam or is it just that one rivet that holds the assembly to the beam? It seems if the screws in the swivel base went into the beam the forward one could hit the trampoline track, but it also seems like more that one rivet would be better.
PostPosted: Tue May 31, 2022 10:06 am
The two aft screws go into the beam. The forward screw is a machine screw held in place with a nut under the swivel plate and does not go into thebeam.
I just replaced a tramp on a H16 and I had to back out the two aft screws slightly because they were scraping against the bolt rope of the rear tramp lacing strip. After I got the strip installed and in the correct position, I tightened the screws back down.
PostPosted: Tue May 31, 2022 10:31 am
Thnaks!
