It is currently Sat Aug 01, 2026 7:46 pm
 Post subject: Make-shift harness
PostPosted: Thu May 03, 2007 6:17 am
Has anyone tried using a climbing harness or even tying a Swiss seat instead of Hobie's full fabric seat. I'm a sailor on a budget.
What sort of results did you have? How was it flying the hull and sailing at the same time compared to a Hobie harness?
PostPosted: Thu May 03, 2007 9:18 am
Don't know about the climbing harness. However, Hobie used to make an economy harness. Just a basic diaper type harness made from sail cloth. If they still make it, it's probably pretty cheap.
Otherwise, you should be able to find a used one pretty easily, most long time sailors have old ones laying around. Also, windsurfing "seat" harnesses work fine.
I wouldn't use anything that has a latching carabiner-style hook. You want to be able to unhook easily if necessary for safety.
PostPosted: Thu May 03, 2007 9:31 am
If you are interested I'm pretty sure that I have two of the old style harnesses that srm is talking about. I'd have to go look up the sizes but I don't think they fit me, I've just kept them around as a just in case I need them kind of thing but if they'll help you get on the wire I could probably get rid of them pretty cheaply.
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Thu May 03, 2007 9:36 am
If he can't help you get ahold of me, I have an extra laying around.
Nacra 5.2 "Elsies"
PostPosted: Thu May 03, 2007 10:00 am
Correction, it looks like I actually have about 4 of them. The sizes aren't marked but I would guess they are somewhere between small and large.
James
Sail # 76909
 Post subject: WTB Harness'
PostPosted: Sat May 12, 2007 11:41 am
Hey I cant get your email from the site so hopfully you will see this reply. I am interested in buying a couple harnesses if you think they are like a large. I wear like a 36 waist, if you think I could fit I will make an offer. thanks man
PostPosted: Wed May 23, 2007 11:21 am
Check out eBay. I have seen quite a few of them there for around $30, including the speader bar (a $30 value in itself)
 Post subject: Climbing harness works
PostPosted: Sun Jun 10, 2007 8:39 am
You can use a climbing harness and one carabiner. Simply put the carabiner in your belay loop and then tape it open so it is attached to the harness, and it will act like a hook. I just used one yesterday in 25mph winds, full extension trapezing, no problems. Full harness is probably a bit more comfortable, but also expensive. Plus what happens if you come across a great little cliff that you want to climb, and you have your climbing rope and gear, what good is a sailing harness going to do? :D
PostPosted: Mon Jun 11, 2007 5:56 am
I can see that, although I would be apprehensive about using it for climbing after all the water exposure.
PostPosted: Thu Jun 14, 2007 12:24 pm
Tried it out with a swiss seat and a hook I barrowed from an old engine lift. It worked great. Could be a bit more comfertable but hey, it was free. And I have a righting strap right there on me at all times. :lol:
cron
