It is currently Fri May 15, 2026 12:10 am
 Post subject: Transducer failure
PostPosted: Fri Jul 05, 2019 7:32 pm
Has anyone had a Lowrance thru transducer fail ...and give false readings (2017 Hook 4 w/chirp / DSI)
 Post subject: Re: Transducer failure
PostPosted: Sun Jul 07, 2019 12:47 am
What do you mean by "thru" and "false readings"?
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Sun Jul 07, 2019 7:12 am
the transducer sits within the kayak hull & shoots thru the hull as opposed to a transom mount or other means. i solved the issue by placing a small amount of water within the small foam mount thats made for this purpose.
PostPosted: Sun Jul 07, 2019 7:19 am
what i meant by the false readings is that the fish finder couldn't find or hold the depth reading, it went from 20ft of water to 2ft for no reason. Also the depth reading was continually flashing , which i'm told is an indication & the evidence that the transducer can't find the depth. which can happen when air is present between the transducer and the hull
PostPosted: Sun Jul 07, 2019 10:39 am
Solution is to stuck the transducer with windscreen joint.
Here's a stripped Airmar TM150 stucked this way...
PostPosted: Mon Jul 08, 2019 6:11 am
Thank you for the tip...did you place a small amount of water between the transducer & the hull ?
PostPosted: Mon Jul 08, 2019 6:20 am
No need, the joint do the job...
PostPosted: Mon Jul 08, 2019 8:42 am
Thank you.
