It is currently Tue Aug 11, 2026 6:38 pm
 Post subject: PA14 Transducer pocket
PostPosted: Wed Jul 24, 2019 5:00 am
Hi All.... new to the forum.
I am planning to making the transition from my current OldTown yak to a new Hobie 360 (currently on order), but had a question regarding the transducer pocket. I'm running a humminbird solix 10 MegaSi G2 and hope this can fit inside the PA14 pocket. I get there might be a need for a custom bracket, but I do not want an external arm like I using today.
I haven't found any specs on the transducer pocket size so I'm hoping someone here might know.
https://humminbird.johnsonoutdoors.com/ ... transducer
PostPosted: Wed Jul 24, 2019 3:44 pm
You should be able to thru-bolt the transducer to the bottom of the plate, which is the preferred method for side imaging transducers.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Sun Sep 08, 2019 6:56 am
I will be doing the same when i pick up my 360 :D what color you getting ? I'm going back and forth !
Here you go this is what i found online may not be same transducer but you will get the idea . https://www.youtube.com/watch?v=n1T57DWs_g8&t=3s
https://www.youtube.com/watch?v=1rHfBaQNudI
PostPosted: Fri Sep 20, 2019 1:34 pm
I have the Humminbird Helix 9 with Mega SI+ transducer mounted on my 2019 Outback. I'll be moving it to the PA 360 when it comes in. The transducer guardian mount is made to fit the lowrance of similar size. The difference is the Humminbird transducer cable comes up from the rear of the transducer. I had to cut a hole large enough to get the transducer to mount flush. Works great and it looks the same as the transducer in your link.
