It is currently Wed Aug 05, 2026 12:09 pm
PostPosted: Sat Jul 27, 2019 12:41 pm
Hey guys,
Long story short, I found a suitable replacement for wing leg caps. Simply put some silicone in the ribbed area and set with a rubber mallet. PERFECT fit and $15 for 8. Link below.
OGC (8 Pack) - 2 Inch OD Round Black for Plastic Plug by Cap Cover Tube Durable Chair Glide Insert Finishing Plugs https://www.amazon.com/dp/B07CN3ZYQP/re ... pDb28JWRXM
These ring gaskets work fantastic in reducing the amount of water entering the sockets, like 97%, link below.
405 Buna-N O-Ring, 70A Durometer, Round, Black, 2" ID, 2-1/2" OD, 1/4" Width (Pack of 5) https://www.amazon.com/dp/B0051XYCNM/re ... pDbBC2CZHC
Really hope this helps others!
Kevin
PostPosted: Fri Jun 26, 2020 7:33 pm
Thanks, I have one cap off and now that you mention it; my heavy air crew might contribute to wear in bottom of socket...?
I have thought of filling the tube / wing arm with "closed cell" foam tubing as extra water displacement security...?
H21SC
PostPosted: Sun Jun 28, 2020 5:35 am
H21SC
Personally, I would not put any foam inside the wing arm. Any water that gets in will become trapped and cause the aluminum to corrode from the inside out, especially if you sail in salt water. If the wings on the 21 are like the 17, then they already have foam plugs inside. On my 17, I pulled out all the plugs and put a small hole in the bottom of the end cap, tapped to accept a countersunk sealing screw which can be removed to allow the tube to drain if needed.
