It is currently Mon Aug 03, 2026 8:42 am
 Post subject: Sad day
PostPosted: Sun Aug 11, 2019 7:21 pm
Started weak ended even worse but great times in between ImageImageImageImageImageImageImageImageImage
Sent from my SM-G975U using Tapatalk
 Post subject: Re: Sad day
PostPosted: Mon Aug 12, 2019 9:14 am
Looks like it would be worth trying to fix. Cut an access hole in the deck and glass the inside. Get some updated crossbar reinforcement plates and install at the rear crossbar. Also see if you can get some glass on the outside (it’s tough to do due to limited space under the lip.
Pretty common failure mode for bosts of that vintage.
PostPosted: Tue Aug 20, 2019 1:45 pm
Great photos of both on and off the water. Thanks for sharing.
Good luck with your repair. You’ll need to add the reinforcement plate kit to the beams and sidestay.
John Forbes
Hobie 18 Reimagined
Sail # 490
Boat name: 18@heart
http://www.hobie18.fun
https://www.facebook.com/Hobie18catamaran/
PostPosted: Fri Oct 25, 2019 2:59 pm
The reinforcement kit was discontinued by Hobie. Look for some used ones. Consider not installing ports, but cutting holes and then glassing them closed, like a pumpkin lid. Installing ports creates another service point for the boat.
Totally fixable though!
PostPosted: Fri Oct 25, 2019 6:52 pm
kinda cool. sail# 113,800 sitting next to 390.
PostPosted: Tue Oct 29, 2019 8:22 am
Great pix, thanks for sharing.
I too, have a dagger board like that!
2015 H16, with spin,
