It is currently Sun Aug 09, 2026 12:24 am
PostPosted: Tue Aug 13, 2019 2:04 pm
I am hoping someone would have some advise on how to repair my 2002 Getaway that has incurred some hull damage. The Hobie was knocked off its lift during a storm and I had mistakenly left the rudders down and locked into place. The port rudder must have hit bottom or a rock and pushed the port rudder and pintle up and out causing a breach in the hull at the bottom pintle. It is not a large damaged area (only about 3"x3") but the roto-molded plastic is damaged and the hull will take on water. I have tried various plastic cements to no avail.
Any suggestions would be appreciated on how to fix this OR if someone knows of anyone with a spare port hull or Getaway of that era (2002) looking to part out.
I would include pictures to this post but I honestly cannot figure out how to do that : (
No Sailing Sadness in Port Clinton, Ohio.
John, Port Clinton, OH
'02 Getaway
PostPosted: Tue Aug 13, 2019 3:53 pm
Perhaps...
A backing plate can add strength and a way to seal from the inside. You would have to remove the molded-in structure that the screws attach to.
It would require the installation of an inspection port on the aft deck.
PostPosted: Fri Aug 16, 2019 8:17 pm
Matt's suggested repair will likely work. The rudders are important and there's a lot of pressure at speed on that attachment...but I'd still try a plastic weld before cutting new holes in the hulls. Be nice if there was anyone experienced local to you; otherwise you gotta become an instant expert.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Sat Aug 17, 2019 8:05 am
The Getaway is made of cross-linked polyethylene which can not typically be welded due to its molecular composition. Molecules of this plastic have all or most all linked. Only unlinked molecules can be welded.
PostPosted: Sat Aug 17, 2019 8:18 am
https://www.youtube.com/watch?v=-tgK_lHWXIE
I have no connection to this company, but their video is specific to repair of cross linked PE. Truthfully, I don't know how well/poorly this would work on a part that is subject to vibration like you get at the rudders.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Mon Aug 19, 2019 5:26 pm
That company makes the KC welder pro and has all kinds of welders. This could close up a crack it seems.
I get the idea now... it makes a mechanical bond as the cross-link material does not melt. You grind out, rough the surface and then melt in a filler material. Not sure about surfaces that get stress... their water tank examples don't have the fatigue loads, but they did fill tanks with water, so does seem to hold a load.
