It is currently Fri Jun 19, 2026 1:52 pm
 Post subject: What else do I need?
PostPosted: Tue Feb 13, 2007 12:22 pm
I am n
PostPosted: Tue Feb 13, 2007 12:31 pm
Authorized Hobie Dealer
congrats your gona have a blast. I always recommend people get a pack of ring dings, clevis pins Hobie part number 30302 wave/getaway pin set, pick up a few packs just to have handy, get some extra drain plugs, you never know when someone else may need yours worse that you do. Did you get the wings, if not go back there well worth it, pick up an extendable hiking stick so you can move around on the boat a bit. I think this is just about it, maybe a set of cat trax
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Thu Feb 15, 2007 7:29 am
Brad,
Yes I got the wings. At first I was against them I wanted the more traditional look like the H-16 but after doing some research the wings are going to make this boat a blast.
Thanks for the heads up on the small parts, this should make for trouble free sailing days this summer.
PostPosted: Thu Feb 15, 2007 3:37 pm
Where will you be sailing? Elkridge is pretty close to the bay isn't it? Bought my Getaway at the end of Sept and have not had it in the water yet.
PostPosted: Fri Feb 16, 2007 7:23 pm
I recommend that you get a pair of extra tiller bushings as well. They go between the rudder and the tiller cross bar. They have a tendency to fail. They're only $4.00 a piece and can be changed out in about 5 minutes. Keep them on board in case they fail while you are on the water.
PostPosted: Fri Feb 16, 2007 8:47 pm
totaly agree about the rudder tendeons, they can break and mess up the whole day!
Brad Stephens
PostPosted: Mon Feb 19, 2007 1:47 pm
Thanks for the heads up on the rudder bushings. I plan to use the boat on a lake in Hanover Pa. most of the time and on the bay. Sandy Point has a nice area for cats.
PostPosted: Mon Feb 19, 2007 1:58 pm
here is an update parts list I think you need to have.
(2)clevis pin set part #30302 $6.02
(1) spare parts kit part#30308 $46.00
(2) tiller tendons part #37561011 $5.90
(1) Hobie mast cradle part #3175 $61.90
(1) hot stick part #fx6 $118
this should have you set for a good year of sailing, don't forget maybe some gloves, a can of McLube. get the spare parts kit and add a couple screw drives in it, pliers, bottle openers, you know the basic tool for survival
Brad Stephens
PostPosted: Wed Feb 21, 2007 12:19 pm
Brad.
Thanks for the good information
PostPosted: Thu May 10, 2007 12:15 pm
I would suggest an assortment of stainless steel (or aluminum) pop-rivits and a pop-rivit gun. We pulled off two cleats and the jib cleats on our first weekend out. We were able to fix and keep sailing. Have Fun!!!
