It is currently Thu Aug 20, 2026 10:14 am
PostPosted: Tue Jan 07, 2020 2:45 pm
Trying to determine if a Garmin Striker 4 CV ... with the extended 6 inch transducer ... will fit in the Compass' transducer mount ...
PostPosted: Tue Jan 07, 2020 4:48 pm
Fits but you have to cut the Hobie plate a bit with a dremel or something.
PostPosted: Wed Jan 08, 2020 8:57 am
Can you elaborate? Do you mean the posts, or something else?
PostPosted: Wed Jan 08, 2020 11:29 am
I cut off the corners of the Garmin piece and the back posts of the Hobie plate. It's secured with 3 zip ties.
PostPosted: Fri Jan 17, 2020 9:25 am
Thanks for this info ... Did you happen to see the PM I sent you? ... was hoping for some more detail ... many thanks
PostPosted: Wed Sep 02, 2020 4:44 am
garmin phone number
Please tell me if I do the same will my warranty expire?
PostPosted: Wed Sep 02, 2020 6:44 am
Modifying the plate would not affect the hull in any way I would think. The only thing we would not warranty would be directly related to this modification. If it stressed some other part or caused damage it might not be covered, but modifications do no "void" warranty.
