It is currently Sat Jun 20, 2026 7:43 pm
 Post subject: Sanding Getaway Hull
PostPosted: Mon Mar 23, 2020 3:19 pm
I removed my graphics because they were all banged up from dock rubbing over the past years... using a razor I removed one side of the graphic stickers..... the next day I realized I just scratched the heck out of the plastic hulls... any suggestions on sanding the hull... what can I do???
 Post subject: Re: Sanding Getaway Hull
PostPosted: Mon Mar 23, 2020 3:54 pm
I am wondering if you could rub it out with acetone on a paper towel. Let's see what others say. Steve.
PostPosted: Tue Mar 24, 2020 8:00 pm
Not sure about this type of plastic, but on many the only way of getting that shine back is with a light touch of a propane torch... If you have some spare plastic, experiment on it... Sanding? Never had luck with that with poly plastics.
ChuckC
H21SE- 408
PostPosted: Sat Mar 28, 2020 3:02 pm
You might try melamine squares. "so called" magic eraser. But get them in China. Only 5 bucks for about 100 of them. It may not work since it isn't really very abrasive (kinda like wet 1000 grit sandpaper). Also try a heat gun, scratch remover for your car's finish, and goo gone. Likely none of it will work, though.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Sun Mar 29, 2020 6:49 pm
Here's a video that seems to work
https://www.youtube.com/watch?v=AL0-pvp2blY
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Mon Mar 30, 2020 11:55 am
Different kind of plastic. The Getaway uses a stiffer plastic that doesn't weld like most kayaks do.
ChuckC
H21SE- 408
