It is currently Thu Aug 20, 2026 12:58 pm
PostPosted: Mon Apr 06, 2020 11:37 am
I have a couple of questions for which I thank any responders in advance.
1. Where can I buy batten tie-in line for my Hobie wave?
I have looked everywhere and no-one seems to stock it.
2. The bridles attach to the forward end of the hulls with a metal fitting that is screwed down.
I want to replace the bridles.
Would I be correct that the screws can simply be unscrewed to remove the metal fitting?
I don't want to hear a small sound of a nut inside the hull dropping off when I unscrew.
PostPosted: Mon Apr 06, 2020 4:33 pm
Yes, you unscrew the padeye to remove the Bridle wire.
If you have corrosion issues... You could cut them off and use a shackle If you can't remove the screws.
Batten tie line is carried by many dealers. It is RH112WHT 18" PER TIE.
This is 1/12" line.
PostPosted: Tue Apr 07, 2020 8:57 am
Thanks Matt.
