It is currently Sun Aug 02, 2026 10:21 am
PostPosted: Thu Apr 16, 2020 5:22 pm
Using my COVID time productively and want to work on the hulls of my 1988 16. They are pretty worn on the bottom but I don't feel any fibers or soft spots. Can I get away with just gelcoating? What product would you recommend for that? Thanks!
[img]imgur.com/a/YnRMuBM[/img]
PostPosted: Fri Apr 17, 2020 8:40 am
Feel the shape. If it starts to feel concave... time for glass. If just gel worn off... don't bother. When it starts getting concave it is an indicator of thin glass.
PostPosted: Fri Apr 17, 2020 9:51 am
The guy at West Marine sold me on this stuff:
http://www.pettitpaint.com/products/epo ... s/ez-fair/
It is easy to apply and shape. Darn durable too.
No sense spending all that effort on glass and gel. It is a "beach cat" after all...the bottoms of the hulls are going to wear as part of their regular and routine use.
Blue Hawaii
77707
Angola-on-the-Lake, NY
PostPosted: Fri Apr 17, 2020 11:14 am
So don't bother until I wear it down enough to do fiberglass and gelcoat?
PostPosted: Fri Apr 17, 2020 4:06 pm
Correct. Gel Coat is relatively soft and wears off more easily. That is only cosmetic. The glass is way more durable.
PostPosted: Fri Apr 17, 2020 6:20 pm
You can use the hull template from the following link:
https://static.hobiecat.com/2010_archive/support/images/tech/hulltemplate.jpg?_ga=2.200418152.774548590.1586875069-2125217696.1586273199
With a copy machine you can adjust the +/- % size adjustment until it matches the scale at the top of page. Trace it onto something that is more rigid and then cut out the template.
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
