It is currently Thu Aug 20, 2026 12:29 pm
 Post subject: Wave beam at bottom?
PostPosted: Wed May 16, 2007 5:24 pm
I know from the Hobie website that the beam of the Wave is 7 feet. Could someone tell me the distance between the skegs (?) at the hull bottoms (which would be the same as the distance between rollers on a trailer)? I want to make certain a Wave will fit over the fenders on a Trailex 16 catamaran trailer, which would require about 70 inches.
Kevin
PostPosted: Thu May 17, 2007 8:46 am
Outside edge to outside edge on the stub keels at the back looks to be 69.25 inches.
Brian C
PostPosted: Thu May 17, 2007 9:18 am
Brian:
Many thanks. Looks like the Wave would just clear the fenders. And the rollers probably hold it above them, anyway.
Best,
Kevin
PostPosted: Thu May 17, 2007 10:09 am
Kevin,
You need to remember that the hulls flare out fairly quickly from the center line of the hull. Be prepared to improvise.
Brian C
