It is currently Sun Aug 02, 2026 5:47 pm
PostPosted: Sat May 30, 2020 2:48 pm
Let's assume you and your beloved H16 (2004) go on a mutual vacation at some far away place where they have not much of anything .... maybe electricity and water, Tequila and some tools, but that's pretty much it.
What are the most important spare parts, tools, ingredients, gadgets or utensils that should come along for the ride?
Thankful for any and all suggestions, and your valuable input ....
Rafael
PostPosted: Mon Jun 01, 2020 9:37 am
Clevis pins, rings, shackles, mast chips, batten caps. Maybe some spare wires, halyard.
PostPosted: Mon Jun 01, 2020 2:53 pm
Mt '85 needed the plastic rudder cams and the special screws to replace the rivets if the cams had never been changed. I also needed the clips that hold the bridle to the hulls. My mast came down in the middle of the lake when one failed. You might consider some fiberglass resin and some fiberglass cloth. I would also carry a fully charged electric drill with some bits and some S/S sheet metal screws. And a Swiss army knife. : )
Howard
PostPosted: Mon Jun 01, 2020 6:35 pm
drain plugs, clevis pins and ring-dings.
PostPosted: Mon Jun 01, 2020 8:26 pm
I’d add some spectra or Dyneema line that could replace almost any line or wire on the boat in a pinch. And some high stent the adhesive tape. And a glass if there is tequila handy.
PostPosted: Tue Jun 02, 2020 8:23 am
Rudder pins...
PostPosted: Thu Jun 18, 2020 1:39 pm
Thank you everybody for your replies.... will comply with all of them ....
and organize all mentioned spare parts ..... very helpful.
Rafael
