It is currently Tue Aug 11, 2026 11:44 pm
PostPosted: Tue Jul 14, 2020 9:07 am
Purchased a 360 2 months ago and been out on it 4 times. While i have watched the out of box video allowing me to set the global adjustment it has not resolved my issue. It seems as though i may have a clutch problem. When letting go of the 360 drive handle it automatically turns to the right and within 2 peddle strokes the boat runs in circles.
https://drive.google.com/file/d/11TikQo ... sp=sharing
Anyone have any ideas? I really dont want to send it back to the dealer for repair because it might take months but, i also cant use it like that, annoying.
PostPosted: Tue Jul 14, 2020 9:32 am
This sounds like the springs in the Clutch are not functioning. Contact your dealer for assistance in placing a claim. Warranty would respond with a repair or parts solution.
PostPosted: Tue Jul 14, 2020 9:37 am
Thanks for your feedback - here is the video i actually wanted to upload.
https://drive.google.com/file/d/1EAsqZv ... sp=sharing
PostPosted: Tue Jul 14, 2020 11:23 am
I have the exactly the same problem with mine. The drive turns right with just a few pedal strokes unless I hold the drive handle. Hobie has a video out on adjusting the clutch. So far that has not solved the problem after about a turn and 1/2 movement. Going to try tightening it more. Does anyone now what the back screw does on the clutch housing?
PostPosted: Tue Jul 14, 2020 12:12 pm
The screw rests against the hull to keep it from bending away from the drive.
Videos: https://www.hobie.com/support/mirage-pro-angler-14-with-360-technology/
PostPosted: Tue Jul 14, 2020 5:16 pm
I tightened the clutch screw another half turn and got better results. It holds straight unless i pedal hard then it rotates again. How tight can I go on the clutch screw? I have turned it probably 2 full turns and a half.
PostPosted: Wed Jul 15, 2020 8:36 am
I would think until the drive starts hitting the other side of the well.
That only holds the drive against the turning gear. You think it skips teeth?
The other setting is the belt tube.
PostPosted: Thu Jul 16, 2020 5:26 am
No, I don't thing the teeth are slipping. Clearly the drive is wobbling back and forth. After the last time i tightened the clutch screw it seems to be working better unless i pedal hard but the drive is now hard to remove.
PostPosted: Thu Jul 16, 2020 7:48 am
I`ll do mine this weekend and see if i have better results.
