It is currently Sun Aug 02, 2026 5:23 am
 Post subject: Boom rigging
PostPosted: Sat Aug 22, 2020 6:29 pm
I have a Harken 3 pulleys on the bottom and two separate single pulleys on the boom. Do any of you know the correct way to run the line through the pulleys?[img][img][/img][/img]
 Post subject: Re: Boom rigging
PostPosted: Mon Aug 24, 2020 6:44 am
On 'newer' H16's, there are two sets of small blocks.
The first set is two single pulleys, underneath the boom, at the rear, which provides a 2:1 purchase on the outhaul.
The second set is at the very front of the boom, upper and lower triple blocks, for the downhaul.
The upper set attached to the connector to the tack of the main sail, the lower set are attached into the mast slot, low down.
The lower set has a cleat.
Do you have any Hobie fleets near you? Any other H16 sailors near you.
In under 2 minutes, once you 'see' how they work, you'll 'get it'.
Welcome to the Forum.
2015 H16, with spin,
PostPosted: Mon Aug 24, 2020 7:30 am
Sounds like my old cobbled main sheet setup in 1983 when we first learned of extreme mast rake. A 5 to 1. As I vaguely remember, a new eye strap on boom for one end of the sheet then woven through bottom blocks back to those on the boom, then through the ratchet. You could rake till the boom touched the Harken.
Any pictured are long gone.
PostPosted: Mon Aug 24, 2020 9:17 am
Thank you for the replies. There are a couple 16's here. I'll see if I can check them out. Mine had a cross over in the pulley lines that didn't seem right. I 180'ed one of the shackles on the boom and it seemed to help keep the lines more straight. We are in southern Baja
PostPosted: Mon Aug 24, 2020 1:15 pm
Gotta love Joe Bennett and JoyRider TV.
Try this YouTube
https://www.youtube.com/watch?v=ZxdYqWGznlM
enjoy
PostPosted: Mon Aug 24, 2020 2:27 pm
Maybe this 5:1 image may help:
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
