It is currently Sun Aug 02, 2026 2:10 am
 Post subject: 194
PostPosted: Mon May 24, 2021 2:27 pm
matt, I remember you said hobie still makes the lower mainsheet triple blocks with cam cleats, but I can't find them anywhere. I found aftermarket stuff but I'd rather go stock. where can I get one? is it the 194? i can't even find the post I read when you said you still make them. thanks, willy
 Post subject: Re: 194
PostPosted: Mon May 24, 2021 2:54 pm
there's an aftermarket 38mm that looks like it can do the job and cost less, but is it worth it considering I'm using stock line? clearance? I won't mention brand names but do you still carry the original lower mainsheet block? That would be ideal. Also, off-hand, is there anyone in socal that does used parts other than craigslist? thanks, willy
PostPosted: Tue May 25, 2021 9:49 am
H194 is still in stock for dealers to order.
https://www.hobie.com/parts-and-accesso ... ry%5D=H194
PostPosted: Tue May 25, 2021 10:46 am
I can only find one that costs about the same as the whole boat did, is there a less high performance, lower cost option? how do you feel about the 38mm size? thanks, willy
PostPosted: Fri Jun 25, 2021 9:01 am
The H194 is the best solution for a Hobie 16. You get what you pay for.
Last bumped by willykaiote on Fri Jun 25, 2021 9:01 am.
