It is currently Wed Aug 12, 2026 5:28 pm
PostPosted: Thu Aug 19, 2021 12:27 am
Hi am new to the form and new to kayaking... I brought a hobie, was told a mirage outback but plate for the serial # has been gone so I have the following question maybe that way i can find the year and model.
1. how to measure the length of the kayak, nose to tail without the rudder? I measure mine that way it's 139 inches. so it's 11'6" no mirage fits that length.
2. once I find the year who do I find spec of it, it seems like there is no where on hobie.com to find spec for older model and perhaps picture of each model so i can compare.
Thanks in advance.
Jon
PostPosted: Thu Aug 19, 2021 2:26 pm
First find the serial number. There is no "plate" to be lost. It is hand engraved in each hull.
https://www.hobie.com/articles/boat-ser ... cation,15/
If an older Outback, you can see old version of websites on Wayback Machine.
https://web.archive.org/web/20180709153042/https://www.hobie.com/kayaks/mirage-outback/
Outback (does not sound like the Outback as it is longer):
SPECIFICATIONS *
Crew: 1
Length: 12' 1" / 3.68 m
Width: 33" / .84 m
Capacity: 400 lbs / 181 kg
Fitted Hull Weight: 81 lbs / 37 kg *
Fully Rigged Weight: 99 lbs / 45 kg *
Hull Construction: Rotomolded Polyethylene
