It is currently Sat Aug 01, 2026 11:42 pm
PostPosted: Sun Jul 14, 2024 11:44 am
OK, so on a FB forum, a member described the Hobie 16 as having a planing hull. He said that at its intended angle of heel, it would plane and that's why H 16s can do 30 MPH.
I understand the intent of the asymmetrical hull is to alleviate the need for dagger boards, that the curve on the inside uses the Bernoulli Effect like an airplane wing (or a sail) to "lift" the hull towards the wind, enabling it to point somewhat higher. Would this "lift" be considered planing? Am I correct in my interpretation of the asymmetric design?
Would any catamaran hull be considered "planing"? I've owned H17s and now a Getaway, both of which have nearly plumb bows and a rounded bottom. I don't think they plane though.
Yet another Bob!
Too many canoes and kayaks
PostPosted: Sun Jul 14, 2024 12:11 pm
The H16 is the farthest thing from a planing hull. Planing is when the bottom of the hull generates enough upward lift that the hull climbs over its bow wave and begins skimming on the surface. Extreme examples of sailboats with planing hulls would be an International 14, Aussie 18 skiff, or a windsurfer. There are some beach cats with flat bottoms that will quasi-plane, but a Hobie 16 is not one of them. A H16 hull is intended to sit down in the water so that the steep sidewall, particularly at the stern, can act like a skeg. Its a hull shape that will never plane.
PostPosted: Sun Jul 14, 2024 1:46 pm
Thanks, SRM, that's what I thought. But this guy had me thinking about it as "planing" riding on a nearly vertical surface working against the wind force. 'Course he also thinks 30 is within reach of a H16 (I think I've read that 26 is about it?), and that a Laser is faster than a Getaway.
Yet another Bob!
PostPosted: Wed Aug 21, 2024 10:31 am
A laser will plane; it might not truly be a planing design but it will get out of displacement mode.
A Hobie 16 won't. It is a displacement design and as pointed out it relies on the displacement to function. I have, however, experienced conditions when sailing solo (lightweight) where it heels and then slides up/sideways a bit out of the water. Not planing, and not even beneficial, but it does it.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Sun Jan 19, 2025 8:11 am
Sorry for the thread resurrection. I’m confused, then. Do cats have different rules for max hull speed? Clearly 20 knots or so is more than the 16 foot theoretical hull speed.
PostPosted: Wed Jan 22, 2025 10:28 am
Correct - catamarans are not bound by the classic hull speed calculation (1.34 x LWL, if I recall) which effectively calculates max hull speed based on the max wavelength of the hull. I believe this is because the catmaran hull is so slender that it is essentially able to pierce through its own hull wave, whereas a monohul would need to climb over its hull wave (plane) in order to exceed its theoretical hull speed.
PostPosted: Wed Jan 22, 2025 12:48 pm
it's sqrt(lwl), and yes, sharp bow and sterns of either cats or monohulls (well under 30 degrees, like rowing sculls) generate too low waves to matter: https://www.yachtingmonthly.com/sailing ... myth-82832
PostPosted: Fri Feb 27, 2026 8:28 pm
A friend of mine used to sail a H16 in Panama on the Pacific side. He told me once he and his daughter got caught in a sudden storm with winds up to 50 kts. The wind was blowing toward home, so he went wing on wing, and they planted themselves on the rear deck hoping to not fall off. He described the boat as planing, which may be inaccurate, but he said it was definitely a different ride from any other experience he'd had. He said the water caught under the lip of the deck and seemed to lift the boat up, which kept the bows out of the water out of a pitchpole situation.
