It is currently Mon Mar 23, 2026 8:29 am
PostPosted: Sun Jun 15, 2025 7:56 am
I would like to buy beach wheels for my Hobie 18SE I understand the 8 foot wheels would fit my boat but I may want to buy a tiger or a Miracle 20.
Would the 8 foot 6 wheels fit my Hobie 18? So that I could possibly use the same wheels if I buy a tiger.
PostPosted: Mon Jun 16, 2025 9:49 am
You can make the axle adjustable if you purchase a section of aluminum tube / pipe about foot long and with an ID a little over 2”. The pipe acts as a sleeve over the axle. You cut the axle in half and one end of the sleeve is permenantly bolted to one of thr axle shafts. The other end, drill a hole through the axle and the sleeve, holding the cradles at the 8 foot width. Then another hole through the sleeve 6” farther out so the cradles can be extended to the 8’-6” setting. Use a clevis pin or a bolt to switch between settings. We had both an 18 and a 20 for a few years and that’s how we did it with one set of wheels.
Found a pic of the extender. Very simple design.
https://www.tackleshack.com/hobie-cat-trax-axle-extender-6.html#gallery
