It is currently Thu Aug 20, 2026 8:01 am
PostPosted: Sat Aug 01, 2026 1:15 pm
Hello!
Been searching the web high and low with no luck for diagrams or something that will help me fix my blowed up rudder up/stowage line.
I was in some thick weeds the other day and Pulled on the rudder line to pull it up and stow it and "Boom"...clearly something broke and the rudder stayed down. Rudder function and directional usage is still intact.
I am now home from vacation and inspecting the craft in the garage and I see what has happened. I believe there is a line that runs from the bow to a pulley somewhere in between the bow and where the rudder up T handle is, and the line running to the bow has broke. So we have the pulley just dangling there with no tension (but all line routing and the rear bungee back by the rudder appear okay). I am able to access the dangling pulley from the center hatch.
My local dealer closed two years ago and my nearest is over 100 miles away so I'd like to solve this one on my own.
The internet is full of how to fix your Pro angler rudder directional problems but not the storage control as far as I can tell.
PostPosted: Tue Aug 18, 2026 5:12 pm
I took some paracord and routed it through the pulley, then used an adjustable grip hitch on the other end of the line to get it as tight to the post by the hatch as possible.
Rudder stowage functionality restored.
The responses and help from this forum were overwhelming :|
(too bad this place used to be an amazing resource)
