It is currently Mon Jun 15, 2026 1:31 pm
PostPosted: Mon Jul 30, 2007 7:59 pm
When do you sail with one rudder up & the other rudder down?
What is the advantage?
Which rudder is up - windward or leeward?
Thank you!
PostPosted: Mon Jul 30, 2007 8:14 pm
Downwind with one rudder. Leeward stays down. Less drag is the only advantage that I know of. If you don't have good cams/locking mechanism you can have problems. In heavy air its probably not worth the effort. Theres too many other things to worry about.
PostPosted: Mon Jul 30, 2007 8:59 pm
I don't worry about it when I am just out goofing around on the lake but if I race I make very sure to life the windward rudder on the downwind leg, especially if the leg is long. I figure that that tiny bit of less resistance might help!
Nacra 5.2 "Elsies"
PostPosted: Tue Jul 31, 2007 7:36 am
Thanks for explaining this. I've seen others sailing with one rudder up before, but I never knew why.
Both rudders kicked up yesterday while sailing in the ocean when I came across a large patch of kelp. I put the leeward rudder back down & sailed the rest of the afternoon with the windward rudder up on all points of sail until I returned through the channel & into Mission Bay. I was on starboard until then so I didn't have to put my starboard rudder back down until I gybed at the end of the channel. I don't know if I was sailing faster due to less resistance, but my H-16 seemed easier to steer with just one rudder down.
 Post subject: Rudder up or down
PostPosted: Tue Jul 31, 2007 9:47 am
Some of the top racers sail with one up, on all points of sail.
Upwind it can be risky as you can cavitate the one rudder more easily.
I have always found the steering to be better with one up on a reach and down wind. Both down causes more drag and some conflict between them.
