It is currently Thu Aug 20, 2026 8:51 pm
 Post subject: Help!
PostPosted: Wed Aug 09, 2006 7:59 am
I have a brand new Mirage tandem which was justed delivered to me on
vacation in Nantucket. Its great. Sailing it by myself was great.
However trying to sail it with a front passenger was impossible. No
response to rudder. As a consequence I collided with a mooring line
(with boat attached) and had the mast yanked back. This ripped out the
the connection of the mast sleeve to the hull and also resulted in a
nice round hole corresponding to the size of the ripped out nub. Is
there any easy fix for this? BTW no Hobie kayak dealers in Nantucket, Ma.
The official response from Hobie was "if it is on the bottom of
the boat - that is not repairable in our opinion as its below waterline
and can leak even with a good plastic weld job. The only repair method s
welding with plastic - a dealer will need to help."
Thanks in advance-Jeff Alter (No relation that
I know of)
PostPosted: Wed Aug 09, 2006 8:53 am
Authorized Hobie Dealer
You can do a plastic weld job yourself, call the closet dealer, see if they have any plastic ships the correct color, then you will need to get a heat gun and make the plastic weld, its not hard just make sure you don't melt the rest of your kayak!
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Wed Aug 09, 2006 12:35 pm
Thank you Sunjammer for your reply. How is the mast sleeve anchored to that nub that broke off? And if it isn't, will it just pull out? Jeff
PostPosted: Wed Aug 09, 2006 1:08 pm
I'm not sure, this is a question for someone else, Matt Miller would be the best, he's at outdoor retailer so not sure how quick he will be. I think it is just molded in, I will do some investigations and try and figure it out.
You have the Mirage tandem.....the sail inserts thru the scupper plug under the front seat.
Do you have the Outfitter...?
Brad Stephens
PostPosted: Wed Aug 09, 2006 5:09 pm
In the '06 boat the mast is inserted just behind the front seat. -Jeff
 Post subject: Mast insert reparation
PostPosted: Mon Aug 20, 2007 10:07 am
After all this time, i hope the problem has already been solved. However, here you have the solution I gave to the same problem on my Outfitter...
http://story-of-a-sailing-kayak.blogspot.com/
The image taken inside the hull shows I replaced de plastic sleeve I broke for a stainless steel sleeve. Also reinforced the base, addind the same material and fixing it to the hull with special silicone.
Enjoy,
Eliseo :wink:
PostPosted: Mon Aug 20, 2007 10:43 pm
Hi Jeff,
Sorry to hear of your mishap. Here's what the mast tube looks llike:
Top, showing threads
Hollow bottom is cut to length for different boats
Perhaps you can twist it out? Good luck -- let us know how it works out. 8)
cron
