It is currently Sat Aug 01, 2026 11:09 pm
 Post subject: HCE tiller connectors
PostPosted: Thu Nov 08, 2007 5:50 pm
Are the European tiller connectors the same as the H20 style connectors?
My boat was a saltwater boat and mine are seixed up on both sides. I tried to knock them loose but they won't budge. I could drill out the rivets and probably disassemble them but from being locked up the pins and the holes on the crossbar are pretty worn.
 Post subject: Tiller Connectors
PostPosted: Thu Nov 08, 2007 6:09 pm
Yes, the Miracle 20 style...
PostPosted: Fri Nov 09, 2007 5:17 am
They're not quite the same.
The H-20 connectors rotate on the tiller arm.
The HCE ones don't. I thought mine were siezed, too - until every Tiger I looked at had the same thing (no rotation).
PostPosted: Fri Nov 09, 2007 5:32 pm
Would it make sense to swap them out then? Seem like alot of unecessary wear on mine.
PostPosted: Fri Nov 09, 2007 7:14 pm
Sure - if you've got $112.50 burning a hole in your pocket. Knock yourself out.
PostPosted: Fri Nov 09, 2007 10:33 pm
I like the ones that do not rotate that are on my FX. I have had problems in past with the 20 style connectors comming loose on my old Hobie 17. The end would get loose.
The new ones that are on the FX are fine for me. But you need to remember to disconnect them before taking the tiller arms and cross bars apart.
I did have a problem with the threaded post that holds the cross bar comming out in a regatta. Fixed that with some thread locker and tightened it back up.
Mike Hensel
'86 Hobie 18, '93 Hobie 14, '80 Hobie 14(restso in progress)
Wind in your sails, water in your shoes, great day!
