It is currently Tue Aug 04, 2026 9:27 am
 Post subject: Crack in Hull of Revo
PostPosted: Wed Nov 28, 2007 4:05 pm
Anyone else have a problem with a crack where the seat plugs into the hull. Came home from fishing and was rinsing it off and heard water dripping inside hull. Turns out the hole that the seat plug plugs into has a crack. Looks like a hard place to weld. Going to bring it into the dealer tomorrow and see what they say. It's still under warranty so hopefully Hobie will make good on it. Was just wondering if anyone else has had this problem. Thanks, Jim
Jim Houle
PostPosted: Wed Nov 28, 2007 4:29 pm
Jim
I have the exact same problem with my Island on both rear seat plugs. Plugging in the seat also widens the crack.
and below is pic of twist tie poked thru crack.
The lighting makes it hard to see but they are there. Put a light into the hull under set plugs and they really show up.
Matt had this to say about the Island:"We have seen some thin seat plug holes.
If you think about how the boat is formed... this is a raised area in the mold. The plastic has to flow up and over the seat hump and the plug holes protrude from that even higher, so it is an area that could be thinner.
There should be no question about warranty coverage on it. I know that roadrunner has done some coating of knob bolt columns inside his hull with a glue material with great success. This may be an excellent material to seal these... at least as a temporary repair so you can use the boat."
My dealer has offered to heat weld my hull under warranty. Hobie has also OK'd a self-repair.
Take a 3/4" PVC endcap and fill it with clear Silicone 2 caulking and place it over the seat plug from inside the hull with the hull inverted (so gravity holds cap in place while it dries). Worked fine for me.
Using DP8010 3M Scotchweld & a PVC cap would even be better. Which I plan to use on my 2nd Island before it's seat plugs also cracks, also if the silicone2 fails on cracked hull.
This fix might even be a good idea to do for all Hobie owners of some hull types before a crack develops. Should be a cheap & easy fix. Kinda like drive well shoe and glue fix/reinforcement kit that Hobie offers for the older Outback.
Yakaholic
PostPosted: Wed Nov 28, 2007 4:32 pm
thanks Yahaholic. I'll post what the dealer has to say about it tomorrow. Glad to see I'm not the only one with this problem. Jim
Jim Houle
PostPosted: Thu Nov 29, 2007 1:19 pm
Went into the Hobie dealer, (Jerry B's) in Corpus Christi and they are giving me a new kayak. No Hassle, just great service. Can't beat Hobie or Jerry B's for service and standing behind their product. Jim
Jim Houle
PostPosted: Thu Nov 29, 2007 1:26 pm
Jim thats great!
Not sure why my Hobie warranty was to have a heat weld repair and yours was for a new hull - considering it was the same problem.
But, hey like you said, you can't get any better service than a hull replacement. :lol:
