It is currently Mon Aug 03, 2026 3:26 am
 Post subject: Internal spin halyard?
PostPosted: Fri Dec 28, 2007 9:41 pm
Has anyone made ran the spinnaker halyard in the mast? Are the HCE boats open all the way through? I wouldn't think it would take too much. The hardest part would be coming out the base and dealing with it in all the downhaul mess. The bottom block would have to be on a swivel as well so you wouldn't have to deal with the mast being rotated away from you.
Or would this not even be class legal for the Tiger/F18? I'm wondering for an FXone.
PostPosted: Sat Dec 29, 2007 7:16 am
13.2 No internal devices are allowed except as supplied.
That's part of the General Rules - it applies to all Hobies.
Not to mention that you compromise the water tight integrity of the mast.
PostPosted: Sat Dec 29, 2007 2:16 pm
just thought I'd ask.
I wonder how they deal with watertight issues with the boats that do have it internally.
PostPosted: Sat Dec 29, 2007 2:48 pm
Those boats just don't turn over!
Nacra 5.2 "Elsies"
PostPosted: Sat Dec 29, 2007 10:11 pm
Call me stupid, which boats are those?
I only knew of internal downhaul :?
Sheet In...Max Out
www.fleet297.org
PostPosted: Sat Dec 29, 2007 11:07 pm
Not the downhaul the spin halyard.
PostPosted: Sun Dec 30, 2007 12:03 am
The INter 20 appears to be internal but it actually runs down the sail track and out at the bottom.
Lots of bigger boats have internal halyards for everything. I know the Farrier 28 tri I race on has internal everything. It is nice, but confusing looking at the base of the mast, and i would hate to have a halyard break and have to rethread it.
Nacra 5.2 "Elsies"
PostPosted: Sun Dec 30, 2007 8:47 am
My main halyard runs back down through the sail track.
PostPosted: Sun Dec 30, 2007 9:05 am
That's my point. Internal main halyards seem commonplace on newer designs. Internal downhaul is less common. Internal spin halyard...on a beach cat? I don't think there are currently any Beach cats with internal spin halyard.
Sheet In...Max Out
www.fleet297.org
PostPosted: Sun Dec 30, 2007 10:15 am
You would have to drill a hole in the mast to run the line out to the pole and make it so it wouldn't just saw away at it...
Anyone running internal stuff through your poles?
Tiger 947/2364
PostPosted: Sun Dec 30, 2007 6:26 pm
Some of the Marstrom boats have an internal spin halyard. I was just thinking less windage, I'd be less likely to forget to rig the spin halyard before putting the stick up (novel idea), and it would be one less line to get caught on the spreader bars.
A through Deck Block. That's all you would need at the top. The one pictured is a might big with a 2.25 sheave. The base of the mast would be a might trickier dealing with the downhaul with another cleat on a swivel in the way. Probably have to machine some of the mast track out of the way to mount the swivel and cleat.
It's winter, I'm bored and just kicking around ideas. It wouldn't be legal so its a moot point.
PostPosted: Sun Dec 30, 2007 8:04 pm
OK. Our Vector (uni-maran) had a small s/s eye bolt (I think threaded into the mast) for the gennaker halyard. It was mounted right at the spreaders.
Douse and sets solo...whew, yeah anything to make that foolproof :shock:
Sheet In...Max Out
www.fleet297.org
PostPosted: Sun Dec 30, 2007 8:58 pm
You just pretend someone else is actually driving and its not that bad. :lol: Seriously steering with your calves is easier than it sounds.
Makes me think that I need to figure out how to do it standing up. Pulling the chute up kneeling is kinda a pain.
Oh the things to try when the water ceases to be solid.
 Post subject: internal
PostPosted: Mon Dec 31, 2007 8:41 am
I've got an internal 2:1 tack line on my N20, and will soon be adding a jib luff tensioner that will run inside the spin pole as well.
There is no need in running your spin halyard internal to the mast. There would be no benefit, and would only lead to a big headache when threading, etc. Not to mention the chaffing that wil occur on the rivet ends inside the mast.
You guys up north need to get out of the cold and head south for Tradewinds in Key Largo (MLK weekend). That cold air must be getting to you...
Trey Brown
www.velocitysailing.com
2006 N20 1017
1998 H16 102698
www.sunjammers.com ftw!
PostPosted: Tue Jan 01, 2008 2:34 am
Anyone heading through Atlanta on their way to the Keys feel free to wave at me on the way and know that I hate you
Tiger 947/2364
