It is currently Tue Jun 16, 2026 11:40 am
 Post subject: 14-16 compatibility
PostPosted: Thu Jan 31, 2008 11:02 pm
Hey all you "experts" (has been drip under pressure) are the 14 and 16 rudder parts the same? I have been looking for some adjustable upper and lower castings and think I found some on a 14. What do you think?
PostPosted: Fri Feb 01, 2008 3:28 am
The upper / lower castings and rudders are identical. 16's tillers are longer, as is the tiller crossbar.
 Post subject: Thanks
PostPosted: Fri Feb 01, 2008 6:06 pm
Thanks. Guess I'll be set to go then.
PostPosted: Sun Feb 03, 2008 9:19 pm
Matt (or anyone else) --
isn't the drill pattern the same on the 14 and 16 rudders?
Peter Nelson
PostPosted: Sun Feb 03, 2008 9:45 pm
I just swap the cross bar off my 16 and put on the 14 one I have and use my 16 rudders on my 14. I guess I would personally say yes to the drill pattern question. They are the same parts.
PostPosted: Mon Feb 04, 2008 4:54 am
Yes, the rudder drill pattern is the same. I'm using an older set of 16 Euro carbon rudders on my 14 - completely interchangeable (with adjustable upper castings).
 Post subject: stuff
PostPosted: Mon Feb 04, 2008 8:52 am
Mbounds, please send me an email: ddbrown (at) ncsu (dot) edu.
Thanks.\\
Trey Brown
www.velocitysailing.com
2006 N20 1017
1998 H16 102698
www.sunjammers.com ftw!
PostPosted: Mon Feb 04, 2008 11:38 am
Why do you need adjustable upper castings? Is the rake different? With the same drill pattern, it isn't as easy as just slipping the high performance blades onto the 14??
Hmmm....last time I sailed a 14 was in 1984. So everyone just clear out and stay away from me! I do NOT have a license or police authorization to sail one of these things!!
Peter Nelson
PostPosted: Mon Feb 04, 2008 12:24 pm
You don't NEED adjustable upper castings, but the hole pattern is slightly different for the adjustable vs. the non-adjustable castings, so you can't easily switch rudders between the two. The adjustable upper castings allow you to make minute adjustments to accomodate slightly different hole placements when you are switching rudders between boats.
The first time I raced my 14, I lifted the entire rudder system from my 16 (changed the tiller arms and tiller crossbar), so I didn't have to touch anything. I used bolts instead of rivets to attach the tiller arms to the upper castings.
PostPosted: Mon Feb 04, 2008 12:35 pm
I did the same thing Matt did, just a little black tape around the 14 rudder arms to take the slop out and some nuts and bolts. Its alot cheaper than owning 2 sets of EPOs!!
PostPosted: Mon Feb 04, 2008 11:04 pm
Peter Nelson will be using my just finished mint condition 14 at the NA's. STAY OUT OF HIS WAY! I once witnessed him arrive from the golf course 5 min before a race. His excellent crew was there waiting with the boat completely prepped. He got out of the car and stepped on the boat. Thought he was hot stuff! We all watched from shore as he slipped on his dry suit standing on the tramp smiling at us all. See Peter is the Division 4 H16 expert. He knew he was going to walk all over us and he didn't even have to try. Moments later he drove his boat into a cement dock. My point is please be very clear on how to make the rudder system work!
I have a dollar that says Peter and my boat finish top ten. Takers?? (Are there cement docks on this course?)
Go Peter!
The Pit Crew,
Jer
PostPosted: Tue Feb 05, 2008 8:35 am
TRUST US, we won't scratch your boat on the line even a little bit............ :roll: 50 tiny POS boats on ONE starting line with 49 Alpha Male personalities (and one Alpha Female) jockying for position. No, your boat is totally safe. No , really. There should be no problem at all.
PostPosted: Tue Feb 05, 2008 10:08 am
You'll just want to stay upwind from chris. Less chance of parts blowing off his boat, and hitting yours.
PostPosted: Tue Feb 05, 2008 10:19 am
I actually have my good mast ready for this event. Plus, there are no Cat trax actually ON the boat, so I can't lose those and there are no license plate on my boat, so I can't lose those........the only thing left is the 3 cans of Busch Light I keep in the tramp bag and I won't let those blow off the boat no matter what!
PostPosted: Tue Feb 12, 2008 8:15 am
Hey Jer, I'll give you the under @ 7 for a buck.
