It is currently Mon Jun 15, 2026 11:18 pm
 Post subject: Hotstick Help
PostPosted: Sun Feb 10, 2008 12:18 pm
Any chance anyone has any tricks or tips for "unsticking" a hotstick?
Division 10, Fleet 185
Hobie 17 and Hobie 14
PostPosted: Sun Feb 10, 2008 1:23 pm
Try this. Clamp the aluminum end in a vice, wrap the outer layer (moving part) with a scalding hot towel or cloth, twist counter-clockwise to release.
Sheet In...Max Out
www.fleet297.org
PostPosted: Mon Feb 11, 2008 8:11 am
spray some silicone down there first. then spray some when you store it and don't store it screwed down tight, leave it loose.
PostPosted: Tue Feb 12, 2008 10:17 am
yep, silicone spray works magic....but if you have sand in there, it can be a bit tricky though, perhaps try to rinse out all the sand first
~vinny
 Post subject: Hot... stuck
PostPosted: Tue Feb 12, 2008 2:45 pm
Submerse entirely in water, then gently work the parts trying to loosen just a little at a time. Once loosened, work the tiller in and out many times to flush the debris out. best with no grip handle on. If you have a cork ball, you may have to remove.
