It is currently Mon Jun 15, 2026 11:50 pm
PostPosted: Mon Feb 11, 2008 2:52 pm
Hi everyone!
I'm reposting my question in a separate thread.
I have found a half inch crack in the luff track lip right at the bottom where comptip starts. Do I need to be concerned with this? Will this grow into something bigger?
I have hoisted sails, sheeted in main block to block and pulled crazy tight on the downhaul. Then I looked at that spot with binoculars and, frankly, did not see much. The mast was forming a nice looking arch at this time.
So do I need to worry about this?
Yuri
Hobie 16
Laser Vago
PostPosted: Mon Feb 11, 2008 3:07 pm
A picture would be very helpful here. Is the crack in the comp tip or on the aluminum part? Either way the luff track is not as load bearing as the rest of the mast and the load is spread along the entire luff track. Depending on the situation a small hole drilled at the end of the crack to prevent it from growing might be in order. Again would really like to see a picture of the issue.
PostPosted: Mon Feb 11, 2008 5:38 pm
It's not a big deal. Just keep an eye on it.
PostPosted: Tue Feb 12, 2008 4:23 pm
Maybe apply some epoxy to the outside. Make sure there is no sharp edge to wear against your sails.
PostPosted: Tue Feb 12, 2008 4:40 pm
Guys, thanks for your advice.
I will keep an eye on this also think about applying some glue. If by end of the week this post is not completely old I will try to put a picture, but I don't think it is important. It is really a small crack.
Thanks!
Yuri
Hobie 16
Laser Vago
