It is currently Mon Jun 15, 2026 3:59 pm
PostPosted: Tue Feb 12, 2008 4:23 pm
Hi guys!
I have bought a snap shackle (part 20803) to attach upper main sheet block to the boom.
The problem is that the opening between the boom and the block hanger (part 10760000) is too small - I cannot fit the snap shackle in.
I'm puzzled why is that? I have called a dealer and they have never seen this.
Is there a different block hanger which is longer? I don't see it in the catalog. I have tried to find a smaller snap shackle but no luck.
Now I sail with a snap shackle attached to the block and with a D shackle attached to the block hanger. But this is too long and ugly.
Thanks for your opinions!
Yuri
Hobie 16
Laser Vago
PostPosted: Tue Feb 12, 2008 4:55 pm
The block hangers (the technical term is a "bail") are standard, but the way they are mounted is not.
A trick to cut another 1/2" out of the mainsheet stack-up is to mount the bail closer to the boom, so that the opening will barely allow a shackle to pass through.
Newer boats come that way from the factory.
Having a snap shackle on the top end kind of defeats the purpose of having a low-profile mainsheet system.
PostPosted: Tue Feb 12, 2008 5:08 pm
That's my vote.Image
I think just the shackle was tight to get through the bail on that boat.
PostPosted: Tue Feb 12, 2008 7:56 pm
OK, that all makes sense.
I have read about minimizing stack-up so this is what I was trying to do, but with a snap shackle in place. :?
See, the way I'm forced to launch my boat most of the time is that if the wind blows at all, then I have to hoist main sail and attach main sheet on the water. So I'm trying to use some help in the form of snap shackle, because putting the D shackle to the bouncing boom over the water is a real trick!
Well, I will see if I can find a different shackle or file off some of the existing one. If none of this works, I always have the original D shackle. :-)
Yuri
Hobie 16
Laser Vago
PostPosted: Wed Feb 13, 2008 4:44 am
Instead of using a snap shackle, use a quick-pin on the traveller car.
PostPosted: Wed Feb 13, 2008 9:55 am
I use both. For some reason, Probably my sail has been recut, but, If I were to take my main Block to block, I would have a 90 degree bend in my mast.
Snap shackles rock!!!!
Sail Like you Have a Pair
Bluish gray 73 - 83 H16
Super Nice Yellow 84 H18
PostPosted: Fri Feb 22, 2008 6:10 pm
Then you need to rake back more!
cheers
Bill
PostPosted: Fri Feb 22, 2008 8:20 pm
You've probably got the old length forestay and shrouds. I know I do, and I can barely get my stacked up 5:1 system block to block with some serious pulling.
1984 H16 - #80541
PostPosted: Wed Mar 12, 2008 7:39 pm
Ok, my question is, as a a 1972-1986 racer, how is this"new" insane amount of mast rake achived? While I am not racing anymore, I am very interested in the idea of increased mast rake allowing me to drive the boat harder in 20-30 knot winds on a reach to keep the bows up.
I am block to block on my 81 hobie, and am no where near the mast rake I am seeing in photos. I am using Harken low profile 6:1.
I am wondering if the boom bale has been moved further back on the bom to allow a little more room? My 81 hobie has 2 bales, I notice the new boats have only one. The rear factory bale on my '81 boat is 24 1/2" from the rear end of the boom. Where are they currently being placed?
So, other than using tiny shackles, re- riviting my boom bale so the shackle will barely fit thru it, what is left other than to move the boom bale further back on the boom? Or am I compleletely off track here?
Also , have the jobs been recut (since 81) to accomodate the increased mast rake? I am running my jib near the top of the chainplate, and am block to block on the jib when I am block to blcok on the main, but still am not achieving the rake I am seeing in others. My jib system, by the way , is the trentech sliders, with a bullet block attached to them.
Raced extensively as a kid (against Matt Bounds!!), just bought a 20 year old 16 and am refurbishing it.
Sail # 21888
PostPosted: Thu Mar 13, 2008 4:06 am
Yes - new jibs cuts were introduced in 2000.
PostPosted: Thu Mar 13, 2008 5:10 am
The upper triple block is a 40mm compared to the older 57mm. It looks tiny but works really well.
PostPosted: Mon Mar 17, 2008 8:58 am
cheers
Bill
That is with a fair amount of rake :) from looking at my Main compaired to others in the fleet, it does appear that the bottom panel has been cut. Also, not sure if it matters or not, but it is from 1973 according to the sail colors PDF .
Sam
PostPosted: Mon Mar 17, 2008 6:15 pm
I think the main is the same. Just the jib has changed in size. Mbounds would know for sure though.
