It is currently Sun Aug 09, 2026 1:17 am
 Post subject: In a pickup bed
PostPosted: Sat Mar 15, 2008 11:53 am
Will the Bravo fit between the wheel wells of a pickup truck?
Do you put carpet or foam down to cushion the hull? :?:
PostPosted: Sun Mar 16, 2008 7:37 am
Sure... In a long bed, fleet-side, full size truck. Won't fit in toy trucks or step-sides. You can make it work in a short bed, but it's kind of ugly.
As for padding, I just have a rubber matt in the bed. I usually put a couple of foam blocks at the bow. The Bravo does ride better bow forward. Helps to have tie down points low in the truck bed.
Brian C
PostPosted: Sun Mar 16, 2008 2:27 pm
Authorized Hobie Dealer
I have a short bed tundra and I put Bravo's in there all the time, I put the stern in 1st so i can leave the a frame, I have kayak racks the sometime interfere with the a frame.
I have a spay in bed liner so I do not put any extra padding in there. Just be careful that the gudgeon's do not get messed up if you go stern 1st!
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
 Post subject: Mast?
PostPosted: Mon Apr 28, 2008 8:03 am
What do you do with the mast?
PostPosted: Mon Apr 28, 2008 4:01 pm
Broke it down into two pieces then tied it to the boat. Sail, battens and "Stuff" went into the cab.
Brian C
