It is currently Sat May 02, 2026 6:21 pm
 Post subject: 10:1 main sheet system
PostPosted: Wed Mar 26, 2008 1:54 pm
is there a conversion for the old 8:1 main sheet system or do i need to buy a whole new system?
Rich Vilvens
F-18 5150
PostPosted: Wed Mar 26, 2008 2:48 pm
Sail Revolution
Join us on our new FB Page!
PostPosted: Thu Mar 27, 2008 9:09 am
Wow, that looks a mess. How do you reave that without friction between the wraps?
Tim
Unofficial Fleet 72 Communications Officer and Div 4 Webmaster
http://www.hobiefleet72.org
http://www.div4.hobieclass.com/
PostPosted: Thu Mar 27, 2008 10:40 am
Surf City Catamarans wrote:
Jeremy,
Are you using a double under the top block? And it looks like you terminate with a bowline through the airblock above the lower block.
And real men aren't afraid to run with purple sheets 8)
2003 Tiger - Don Atchley
PostPosted: Thu Mar 27, 2008 11:14 am
I agree. Eventually you're going to reach a point of diminishing returns where the friction in the system exceeds the theoritical mechanical advantage. Might be better off just hiting the gym a little harder.
PostPosted: Thu Mar 27, 2008 1:01 pm
Harken sell a 5 sheave top block that makes it a lot easier to get 10:1. Unfortunately you need to go to a Nacra dealer as they are custom made for Nacra. Works well
PostPosted: Thu Mar 27, 2008 1:06 pm
joclo
Ifoung the 5 sheeve system at murrays marine, and my local hobie cat dealer is trying to find me one now through his suppliers. Go jeremy surf city catamarans can find anything and usually has the best prices.
(and if i don't buy from him his kid might go to a college without a sailing team)
jk
but thanks all for the input
i'll put picks up when i get the system from jeremy
Rich Vilvens
F-18 5150
PostPosted: Thu Mar 27, 2008 1:07 pm
Jeremy,
Yep to all that. I built this system over 4 years ago and it's still going strong. Now, Harken has a 5 sheave upper which simplifies things a little. I think the 5 sheave pulls a little funky myself, but that's what people are going with these days with minimal problems.
I just built a tapered mainsheet for the above system, and it got great reviews. I suck at tapering, but this once it came out pretty well. I used 6mm FSE Robline 8 plait dingy through the blocks and 8mm FSE Dyneema racing sheet in the hand. I won't show you a pic, you'd just laugh at how funky it looks. The materials are top notch, and functionally it works great, the execution is where is suffered.
I'm solid in my masculinity, D! :lol:
Sail Revolution
PostPosted: Thu Mar 27, 2008 1:13 pm
They are slightly back ordered from Harken, should be a few days.
They list for $175
$434
We all get our parts from the same place, make sure to support you most local Hobie dealer, so they can support your local fleets and races.
Sail Revolution
PostPosted: Tue Apr 01, 2008 10:25 am
That double hanging on the triple's plastic becket will break. Mine did...it took about three years but Harken said that was a no-no and would not warranty it..
I am using the Quint on the top now with the triple and a double on the bottom, attached to a metal becket.
PostPosted: Tue Apr 01, 2008 10:33 am
Erf, anything past 8:1 starts getting really complicated. A center-sheeting 5:1 along the boom with a 2:1 cascade from sail to traveller starts looking less and less messy...
Tim
PostPosted: Tue Apr 01, 2008 6:02 pm
More stuff to get caught on when ducking underneath it. Plus does it give you enough adjustment range?
2008 Hobie Tiger
PostPosted: Tue Apr 01, 2008 6:14 pm
I don't think those booms could support it anyway, at least not the round style.
PostPosted: Wed Apr 02, 2008 7:45 am
Probably not. Plus a center-sheet would get in the way of crew - more popular on the A-Cats. In that case, the 10:1 is in the usual spot and just the end of the sheet goes along the boom, so it's only 1/10th of the load axially on the boom, instead of 1/2 like my example.
Tim
PostPosted: Wed Apr 02, 2008 5:28 pm
Sooo, what system / ratio is the best if you had to upgrade now?
Tiger 1047
