It is currently Mon Aug 03, 2026 3:34 am
 Post subject: Weird Cracks - UPDATED!
PostPosted: Thu Dec 16, 2004 4:45 pm
I have these weird cracks on the right (Starboard) Hull on the right side of it, from about a foot from the front to about a foot in front of the fore pylon. Now when I push down on them, there is not soft spot,. but if I lift from the side where the little overhang is, and really force it, I can make it sound like its cracking. what is this and how can i repair it... now im going to be painting my boat within the next week, so I was wondering if I can use some sort of marinetex hardner or something to seal these cracks.
 Post subject: Looks like rail damage
PostPosted: Fri Dec 17, 2004 12:33 pm
Looks like rail damage rather than a delamination of the foam in the deck. A bump against something? I would grind down the gelcoat under the lip and layup some glass to stiffen it. I would thin out some clear resin and pour into the cracks on the deck to seal it.
PostPosted: Fri Dec 17, 2004 1:39 pm
Thats cool, they are in a non-important area, so maybe they are from something being bumped into the hull, I dont know I just bought the hulls. is this safe to sail with still? I will sand it down and put some epoxy to harden them up though, before I paint it!
PostPosted: Fri Dec 17, 2004 1:44 pm
Yeah man, if I were you before painting it I'd sand down the area and lay one or two layers of (bidirectional) glass over it. Then if you don't want texture there, use some microbubbles mixed into epoxy (peanut butter consistancy) to fill the weave. Sand again, then paint. :)
Warm regards,
Jim
PostPosted: Fri Dec 17, 2004 8:38 pm
A Hobie dealer in Austin Texas told me to use some marintex before I paint becasue those cracks are only gelcoat layer deap, then sand it then paint, and they should be fine... What do you guys think? Or should I go with sanding and re-gelcoating? That 1 picture doesn't do it justice, there are cracks for a good 3-4 feet down the right side of the right hull...
PostPosted: Fri Dec 17, 2004 10:32 pm
If they really are only gelcoat-deep and not structural, then yes Marine-Tex would be fine. I'd sand it down a little bit first to find out, though. :)
Jim
 Post subject: Sounded like cracking?
PostPosted: Sat Dec 18, 2004 9:26 am
Sounded like cracking when pulled on? I would stiffen up the lip from the under side. The rail / deck is a structural issue in the bows. Lots of stress up there. How about rigging it up and sheeting hard. What does that do to the cracks?
PostPosted: Sat Dec 18, 2004 7:14 pm
Dont know, but the cracks are only in the gelcoat.. I had it looked at, and I will sand it down a tad and maybe adda a layer of bi-directional glass then paint it!
PostPosted: Sat Dec 18, 2004 7:25 pm
and those noises take quite alot of up pressure to make them do it!
 Post subject: no big deal!
PostPosted: Sun Dec 19, 2004 5:24 am
I sail on hulls with the same kinds of cracks. I beleive them to be mainly cosmetic. Never had any cracking sounds or anything. These hulls have been sailed hard by me and before that they were raced hard (by an A fleeter) with the same cracks. They haven't spread since I've had them although I would at least recommend filling them to prevent water from geting in. I have never had any problems (the pointy parts is still there) even with the heavy load those lips experience. That being said, if you have hulls old enough to have these kind of cracks its not like you need to worry about a little extra weight from some reinforcing glass and resin. You definitely don't have to worry about the bows falling off if you sail it before you do the work though (provided you don't have any delamination in the hulls).
Matt G.
PostPosted: Sun Dec 19, 2004 5:34 pm
Nope.. purly cosmetic... the cracks dont go deaper than the gelcoat layer, they dont even come close to the fiber-glass... gonna spend the Ney Years Weekend using some marinetex putty for all cracks that i find, then sand them,,,, then im gonna paint it.
Thaks For your help all.
PostPosted: Sun Dec 19, 2004 5:41 pm
Marine-Tex is the bomb. Be sure to post lots of pics! 8D
