It is currently Mon Aug 03, 2026 8:08 am
 Post subject: kick up rudders
PostPosted: Wed Apr 09, 2008 10:44 am
We bought a 86 Hobie 16 at the end of last summer and didn't have too many chances to sail it before the end of the season. We have some sprucing up we want to do this spring.
Anyway last summer we had trouble with the rudders kicking up upon reaching shallow water. They wanted to stay locked down. What parts do we need to look at or replace to fix this problem?
PostPosted: Wed Apr 09, 2008 11:37 am
I'd check the cam located within the lower rudder casting. Check for full rotation and also check the cam locking pin and associated spring for correct operation. If any parts are worn I'd recommend replacing them. You'll find other advice in this forum with more detail. Your local Hobie dealer can also help you. This is a fairly simple mechanism designed to save damage to your rudders upon hitting something underwater.
Hope this helps some,
Eric
H16
Sail# 11500
PostPosted: Wed Apr 09, 2008 11:41 am
You can read-up on the subject here:
http://home.earthlink.net/~mattson/hobi ... ature2.htm
Eric
H16
Sail# 11500
 Post subject: rudders
PostPosted: Wed Apr 09, 2008 1:17 pm
Thank you for the help and the link.
PostPosted: Wed Apr 09, 2008 1:32 pm
Make sure all of the system components are properly lubricated. Also, if you look up into the bottom of the lower rudder casting, you will see a fairly large plastic screw (about 1/2" dia). This screw sets the pre-load on the plunger spring. Loosening this screw reduces the force required to kick up the rudders (and vice versa).
PostPosted: Wed Apr 09, 2008 1:42 pm
Marine grease applied to the cam and plunger helps also.
