It is currently Mon Jun 15, 2026 1:00 pm
 Post subject: Aluminum trailers
PostPosted: Sun Apr 20, 2008 6:32 am
Just got back with my new to me Hobie 20. The great part was it came with an aluminum trailer. I was amazed at how well the trailer tracked. I had about 75 pounds of tongue weight and ran 80-85mph for 500 miles. It never even swayed when I changed lanes. My 16 used to be all be all over the place with the galvanized trailer. I'm sure the over all weight helped, but did the lighter weight trailer have anything to do with how it tracked? I think it's true, once you go aluminum you never go back. :D
PostPosted: Sun Apr 20, 2008 8:01 am
Buzz,
First off, congratulations on your new acquisition. You have an exciting summer of sailing and learning about your new boat ahead of you.
Now, on to the trailer issue. I seriously doubt that the material used to build the trailer has much to do with the way it behaves behind the tow vehicle. Many other things affect the characteristics of how a trailer tows. Weight is certainly an issue, but more than the overall weight is the distribution of the weight. Too much tongue weight puts an unnecessary load on the towing vehicle, too little tongue weight will cause the trailer to "walk" or "sway" behind the vehicle. In extreme cases when towing VERY Heavy trailers if you don't have enough tongue weight, you get into a "Tail wagging the Dog" scenario. If you ever have it happen to you, you will never ever forget it. keep in mind, that even a double or triple stacked set of Hobie's lacks the weight necessary to do that.
Other things that affect the way a trailer behaves are distance from tongue to axle, tire size, and number of axles.
I've seen Canadian Hobie 18 sailor Paul Evendon add a "tag axle to a trailer for towing a triple stack of 18's, to help control the side sway. Primarily, I think, to spread the weight over 4 tires instead of two and also to eliminate the need to change a flat on the side of the Interstate. even if he had a flat, one tire on a side would get him to the next off ramp and out of harms way. I think he felt that was necessary because the windage of passing Semi's would rock the trailer so badly he was worried about it blowing off the jack while changing the tire.
The closer the axle is to the tongue of the trailer, the more quickly the trailer will change directions when backing. An example is those little bitty jetski trailers are a biatch to back up because they over react very quickly to any change in steering angle.
The advantages of an aluminum trailer are obvious to even the most casual of observers, Light weight, and corrosion resistance.
The down side is not so obvious, compared to galvanized steel aluminum is significantly more "brittle". While I have never had the pleasure of owning an aluminum trailer, my neighbor has one for his power boat, and he is fanatic about checking all the welds before, during and after every trip. He has had to have a couple of the "stress points" on the trailer rewelded on a couple of different occasions.
Once again, Congratulations on you new toy, have fun learning to sail it to its potential, and keep an eye on the welds and stress points on that new trailer.
Stephen
If the grass is greener on the other side of the fence, maybe it is time to water your own lawn.
 Post subject: Trailering
PostPosted: Mon Apr 21, 2008 7:44 pm
I think there maybe some additional reasons the H16 sways around alittle bit vs the H18's and H20's. The H16's tramp sticks up into the airstream and acts like a sail/parachute. The H18 and H20's tramps are lowwer and effectively sheilded partially by the hulls.
Harry
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Mon Apr 21, 2008 8:17 pm
You and your aluminium trailer should haul your 20 out to Yankton (1 million miles west on I-90) for the 20 NAC.
See you there!
PostPosted: Tue Apr 22, 2008 11:51 am
It doesn't ride that great. Just kidding. If it wasn't for my parents 50th anniversary June 7th in Hilton Head, I would try to make it. Mapquest says 14 hours which means 10 with the aluminum trailer. :D
PostPosted: Tue Apr 22, 2008 3:29 pm
Sometimes I'm glad I'm an orphan.
PostPosted: Sun Apr 27, 2008 10:29 am
The consolation is that I'm taking my H20 for the week. So I plan on terrifying the whole family. This way I may never be invited to future events. :D
