It is currently Tue Jun 16, 2026 4:37 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Your best modifications
PostPosted: Sat May 10, 2008 8:16 pm
I have seen some cool mods here. Can you all show me your best. I love to see what you have done!
PostPosted: Sat May 10, 2008 9:19 pm
I tried to convert my H14 into a submarine. It didn't pan out....
PostPosted: Sat May 10, 2008 11:34 pm
Of all the modifications I've made to my boat, I'm most impressed with the "trap return system."
In addition to making the transition to the wire much smoother, the bungee doesn't pull me or my crew forward when we're aft on a reach or downwind. :roll: It also makes the boat easier to rig as it's already anchored under the tramp. I know it looks complexed but it's really simple. :)
Happy Sailing,
David
PostPosted: Sun May 11, 2008 12:04 pm
In addition to making the transition to the wire much smoother, the bungee doesn't pull me or my crew forward when we're aft on a reach or downwind. It also makes the boat easier to rig as it's already anchored under the tramp. I know it looks complexed but it's really simple.
Matt,
Is this a class legal modification????
Stephen
If the grass is greener on the other side of the fence, maybe it is time to water your own lawn.
PostPosted: Sun May 11, 2008 3:34 pm
Matt,
Stephen
The rules are silent regarding trapeze shock cord return systems (both the general rules and the Hobie 16 rules).
However, General Rule 9.4 states:
[quote]9.4 No portion of the deck, or deck flange where
present, shall be altered, removed, cut down, or
in any way modified except as allowed herein.
The rear transom flanges, where present, may
be notched a maximum of 2 in. (5 cm) to accept
larger gudgeons or to repair breakout at the
rudder pin. Water tight deck access portholes
may be installed.â€
PostPosted: Mon May 12, 2008 8:00 am
DavidBell47,
What does it say in the first line in the Instructions? I could not read it on the picture... :)
Yuri
Hobie 16
Laser Vago
PostPosted: Mon May 12, 2008 9:19 am
Not that it makes any difference to me because I do not race, are the second holes behind the shrouds, not from a righting system? If yes, is that system stock? If they are stock, can you not use them for different purpose than originally intended?
Sam
Sail Like you Have a Pair
Bluish gray 73 - 83 H16
Super Nice Yellow 84 H18
PostPosted: Mon May 12, 2008 9:31 am
On the stock boats, there is only one hole on the outside of the deck lip for the shroud attachment.
<<<<Since David's system uses holes through the deck flange, I think it violates this rule. >>>
We have been drilling holes in the flange for rear footlloops since 1972. This isn't any different.
Jack Woehrle
Wave #100
H20 #287 "Tallahassee Lassie" (down in FLA)
PostPosted: Mon May 12, 2008 9:40 am
Actually, it is different. Footstraps are specifically allowed:
6.7 Foot straps may be installed on the crossbars,
sidebars or hulls.
(Hobie 16 rules)
PostPosted: Mon May 12, 2008 10:47 am
<<<<Actually, it is different. Footstraps are specifically allowed: >>>
OK, drill 2 holes and make a very small "footstrap". Is there a rule that says you can't tie a block to your foolstrap?
I assume that a "footstrap" doesn't have size limitations.
Jack Woehrle
Wave #100
PostPosted: Mon May 12, 2008 11:20 am
4. LOOPHOLES
IF YOU THINK YOU HAVE FOUND A LOOPHOLE,
READ THE PRECEDING STATEMENTS
AGAIN. THESE ARE THE BASIS OF
THE RULES AND COVER ALL AREAS NOT
COVERED IN THE RULES. GENERALLY, IF
YOU CANNOT FIND IT LISTED IN THE
RULES, IT IS NOT CLASS LEGAL. IF YOU
ARE IN DOUBT, CHECK WITH THE IHCA
FIRST. APPROVAL MUST BE IN WRITING.
This is the only section in the rule book that's all caps.
PostPosted: Mon May 12, 2008 11:33 am
<<<<This is the only section in the rule book that's all caps.>>>>
I know the "loophole" rule.
I was just jokin' about a "small footloop".
Not to change the subject, but I am sorta upset that this so called "one design" class (H16), where you can't drill an extra hole, saw wisdom in building lighter boats, thereby making virtually all of the older boats uncompetitive.
What say you about that?
Jack Woehrle
Wave #100
PostPosted: Mon May 12, 2008 11:45 am
I would say that a 25 year old boat would be uncompetitive no matter what it weighs.
The weight change happened in 1983.
 Post subject: Older boats
PostPosted: Mon May 12, 2008 12:29 pm
Forgive my ignorance, but if an old boat is maintained it should still be competitive with occasional mods etc. (In a one design class)
The new hobie with lighter hulls, different profile rudders etc etc is a damn fine boat but is quicker which is an unfair advantage over the older boats - money again determines who wins.
To retrofit and modify the older boats to a newer spec is too expensive. Maybe hobie should make the parts more affordable for the rest of us.
In todays age hobie has to be competitive with newer design, manufacturing and material choices etc, so it is nice to see the new machines. Surely the handicap rating would be different, or should be.
The trap guides that hobie sell in the catalog don't mention whether they are race legal or not - mounted under side rails. Personally I think it is too far back for my use, extension catching.
