It is currently Mon Aug 03, 2026 7:28 am
 Post subject: Tuning
PostPosted: Wed May 14, 2008 6:09 am
Novice sailor here that would appreciate an old salt's nod -
@ 250# solo, mast rake should be as far back as possible.
In order to reduce tiller pull, rudders should also be raked maximum forward. (If raked to far forward, may cause boat to Lee Helm)
Rudder trim should be set with + 1/4" trailing edge.
Anything else that I should take a look at?
PostPosted: Wed May 14, 2008 6:39 am
that your tramp is as tight as possible! :lol:
'83 H16 Tequilla Sunrise and Cat Fever
PostPosted: Wed May 14, 2008 7:44 am
1/4" bow on the rear, 1" each side.
PostPosted: Wed May 14, 2008 11:40 am
Read a book on tuning - there's just too much for this forum to handle. After reading a book and sailing then come to this forum for tips, where folks are happy to dispense the wisdom of their experience.
 Post subject: Re: Tuning
PostPosted: Wed May 14, 2008 12:17 pm
Sounds like you have most of it covered.
Use the main traveler (let the car move outboard) if the boat flys a hull too easily. Will sail faster trimmed tight and traveled out.
Have fun!
