It is currently Mon Jun 15, 2026 8:27 pm
 Post subject: H16 - H18 Mast extrusion
PostPosted: Mon May 12, 2008 2:25 pm
Question for Matt Miller
Do they/ Did they use the same aluminum extrusion for the H16 and H18???
I'm trying to use some "bent" H16 and H18 masts for a project .... I don't have enough of any one ... but I do if I can use both H16 and H18 as I have two of one and one of the other.
Harry
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Tue May 13, 2008 2:38 pm
The 16 extrusion is more teardrop shaped than the 18. I used a 16 section as a sleeve on a 18 mast by cutting off the luff track. They are close but different.
PostPosted: Tue May 13, 2008 5:28 pm
This may interest you
http://www.youtube.com/watch?v=A6Jz4_PpHLY
http://www.youtube.com/watch?v=TxOf5_OdFss&NR=1
http://www.youtube.com/watch?v=FPBDnZiu ... re=related
http://www.youtube.com/watch?v=O687PMgI ... re=related
Not sure how you'd form the sail track.
TC
PostPosted: Wed May 14, 2008 12:04 pm
Yes, they are different profiles.
Depending on what the project is... may not matter.
PostPosted: Fri May 16, 2008 10:28 am
Thank you for responding Matt and confirming what a previous post had said.
Are the extrusions the same wieght/ft???
I'm trying to gather material/parts for a little "homebuilt" cat. The bent masts maybe good for crossbars.
some people at our club do not tie their boats down .... thunderstorms like to throw them around ... end result, bent mast!!! Or trees fall on the stored boats in the storage yard ... bent mast!!!
I like to be "crafty" and turn junk into "good parts" .... I'm tired of watching "The History Channel".
Harry
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Fri May 16, 2008 10:47 am
Better PM Wouter to have him run your calc's for using H16 mast sections as Blade beams :P
Sheet In...Max Out
www.fleet297.org
PostPosted: Fri May 16, 2008 3:23 pm
I would expect the 16 mast profile is tougher, thicker and heavier per foot. The 18 was designed to use diamonds.
PostPosted: Fri May 16, 2008 3:34 pm
Duhhh .... that would make sense.
Thank You, Matt for your response ....
I do LOVE my H18 .... but the H16 is one TOUGH boat and I've seen them sail through some OUTRAGEOUS conditions where no sane sailor should be !!!!
Harry
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
