It is currently Sun Aug 09, 2026 8:00 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 15, 2008 2:12 pm
Thanks for the help guys, now can someone call the dealer and tell them to hurry up putting the boat together? :P
Sail.fast
PostPosted: Thu May 15, 2008 8:10 pm
Curious why Hobie would not have done a pull test on the tang? So if we don't know what the max load the tang will take then we can't put a value on the max weight of a hiked out sailor either??
PostPosted: Fri May 16, 2008 5:46 am
mmiller wrote:
Don't think is is held in by anything but the rivets.
Oof! Recommendation noted.
Brian C
PostPosted: Tue May 27, 2008 1:40 pm
mmiller wrote:
The tang is mounted quite a few inches (foot or more) up in the CompTip. No change since the original Getaway came out. Unless the factory is keeping a secret from me :)
BTW, the tang fasteners / rivets seat into a backing plate of aluminum inside the CompTip.
On a similar but different topic -- I got another mast tang and rivets to mount in the comp tip to fly a spinnaker. When I was reading about "Steve's Getaway Mods" I didn't notice anything about needed a backing plate. If I mount the new tang with just rivits is it likely to just pull out?
PostPosted: Wed May 28, 2008 10:26 am
It is typical to simply rivet a spinnaker tabg in a CompTip without much concern.
PostPosted: Sun Jul 06, 2008 9:43 pm
Is it possible to add a dophin striker to the Getaway ?
Would that solve all the issues relative to having a double-trapeze on the boat ?
