It is currently Fri May 15, 2026 1:47 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu May 22, 2008 10:37 am
I don't know about the differences between the Club version and the other(s), but the Club tramp is simple and efficient.
Sailing Texas has a video showing rope tightening on the tramp using two pairs of vice grips that looked extreme. There appears to be a natural bind with the grommets that doesn't require that much force with the Club tramp. One pair of vice grips to lock the rope down while threading is an extra hand.
It's a good design.
@ gattler
Using a mast stand or the cradle or both? Is the 16 cradle made to fit over the traveler bar? The 16 cradle (part 3175?) fits on the rear crossbar. If you have the time, a pic, part #, or further explanation? Thanks in advance.
PostPosted: Fri May 23, 2008 8:32 pm
Looking closer at the pic in the catalog, it apparently is so.
PostPosted: Sat May 24, 2008 5:28 am
Authorized Hobie Dealer
yes it will, not sure on this but you might be able to use 2 H16 mast cradles in the rear if you needed to take the mast apart.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Sat May 24, 2008 9:05 pm
Thanks, Brad.
Am using a trailer crutch/cradle and ordered the 16 mast cradle for the rear. Plus the halyard tied to the cleats after going through the pulleys at the top of the mast seems to be holding the halves together OK. Mast halves come apart and go together fairly easily -- almost too easily.
I would tinker around and make a mast cradle myself but too much sweat equity involved.
However...
I do have one other question about mounting the traveler kit.
The swivel cleat comes in one bag and the mounting base for it in another -- and in the swivel cleat bag there is what appears to be an extra mounting base.
I am going to assume that you discard this "extra" base. The instructions don't say.
The base and the swivel cleat are mounted to the crossbar with the same set of screws, according to the instructions.
Thank you for the pics, btw. Extremely helpful, they are.
My old pop rivet gun is ready to roll!
PostPosted: Sun May 25, 2008 6:25 am
the swivel cam cleat come with a round spacer looking thing it will not be used. Yes the cleat is help to the mounting plate with the same screws.
Old pop rivet gun? I hope it a big one. Make sure the head of the rivet gun stays in contact with the rivet the entire time, or else the rivet will not be flush when "popped" and he traveler car will not clear the top. If the rivet gun will not fit in the track you will need to make a spacer out of some washers.
Give me a call if you have any questions and I will try to explain more.
Brad Stephens
PostPosted: Tue May 27, 2008 9:32 am
A good point about pop rivet gun!
I did a lot of pop rivet work while making ductwork in a sheet metal shop when younger and many times had rivets came out when I got too much in a hurry and didn't hold the gun down securely to the metal while squeezing the handles.
PostPosted: Sun Jun 01, 2008 9:13 am
Geeez...
Why'd you hve to post the picture of the traveller??
Now, I want one, but have a CLASSIC, so I guess I am going to have to come up with another design concept.
Anyone have any ideas how to make a traveller work/look good on a CLASSIC?
PostPosted: Sun Jun 01, 2008 6:50 pm
zzcoreyzz wrote:
Geeez...
Yup, I too have a classic. In order to do away w/ the velcro straps, I am installing lacing posts, (see the H20 rear crossbar detail in catalog for part numbers for posts/rivets) which will enable lacing up the rear like a Getaway or H20. Per Matt Miller's suggestion.
I will place the posts at the rear of the crossbar, about midway around, (opposite side of slot), rivited at the same interval as the straps. I was originally going to go with 4 posts, but I think I will double up at the strap locations. I think 8 posts will hold stronger and more evenly than just the four. Once posts are installed, I will use some 3/16" lacing line, more or less following the lacing instructions from the Getaway assem manual. Have yet to do it, but it should work fine, and hold better tramp tension than the velcro. Parts are in I think, just need to go get them.
Jim
2007 Hobie Wave
PostPosted: Mon Jun 02, 2008 10:56 am
This traveler kit installation is not easy.
The track slot is 3/8" wide and 3/8" deep and most good pop rivet guns are not that narrow or extend that deep.
My gun -- after putting washers in as spacers -- will just barely grab the end of the rivet. The gun is a professional model. At any rate, I have backed off until I get the right tool or rivet.
EDIT:
Got it!
1. Removed 3/16" nose from new $9.95 Sears gun and filed down to less than width of track slot with my new $6.95 file.
2. Because still not elevated enough, drilled 3/16" hole in scrap piece of steel that is just thick enough to keep the rivet gun from touching the bar. Then hacksawed small rectangle out of the scrap metal with hole in center to fit in slot.
With two-handed power squeeze on the gun, it riveted OK. And pushing down on the gun is a must as handles are squeezed to keep the rivet from jumping out of the hole.
Whatever is between the rivet head and the gun -- whether washer or steel plate with 3/16" hole like I made -- has to be flat and about the same size as the rivet's diameter. Because it compresses the head. If anything other than flat surface with as near 3/16" in diameter hole for rivet is used, a raised impression is left on the head after you pop the rivet... and the traveler has something to hit.
In other words, something that looks about like the flat surface of the nosetip that comes with the rivet gun is needed.
PostPosted: Mon Jun 02, 2008 8:19 pm
Jim,
Sure, that sounds like it will work, but it seems like the whole car top portabilty/assembly/disassembly takes a big hit. And, of course, that is a big reason I bought a CLASSIC. No trailers and insurance. no boat ramps, no storage problems.
PostPosted: Tue Jun 03, 2008 3:50 am
zzcoreyzz wrote:
Jim,
I see your point. For me that is not so much an issue, as I keep it in one location assembled all season. True, it would be a bit of a pain to unlace/relace, but may not be that bad either. It is only the rear. It may take an xtra 5 min? Take a look at the Getaway assmebly manual in the support side of this site, it will give you an idea what is inolved. Eight posts instead of the 10 on Getaway.
Once I actually do the mod, I will post my results, and I will time the process once I have it down.
Jim
2007 Hobie Wave
PostPosted: Tue Jun 03, 2008 8:10 am
Please do! Count me in as another Classic owner interested in this upgrade.
PostPosted: Sat Jun 07, 2008 9:12 am
Thanks, Jim,
I look forward to it.
PostPosted: Sun Jun 08, 2008 9:03 am
wannahobie wrote:
zzcoreyzz wrote:
Jim,
Well, finally got the parts and did it! Boy those monel rivets drive hard!! Anyway, lacing posts are installed, lacing in place, very easy to lace, took m about 10 min, but only because I needed to figure out the pattern w/ the eight posts, and cut lines to lenght, etc. Realistically, probably could be undone in about 30 sec or less, to re lace maybe a couple min once it is down.
So, no more velcro straps! Traveller-ready!
I will have pics, part no's, instructions to post soon. Off to the lake to sail now :D
Jim
2007 Hobie Wave
PostPosted: Wed Jun 11, 2008 5:55 pm
Traveller kit on SE / Classic Wave? Yes it is possible!
Eliminate the straps! Use H20 lacing eyelet posts and lacing...
alternative to lacing, shockcord as I switched to..
I originally documented it all here, but decided to move it to a NEW topic: http://www.hobiecat.com/community/viewtopic.php?p=52178#52178
Jim
2007 Hobie Wave
