It is currently Tue Jun 16, 2026 2:21 am
PostPosted: Sun Jun 08, 2008 7:32 pm
I've noticed a slight bend in my mast. :( Unrigged, you really struggle to see it but once the downhaul is cranked on full you can really see it. It leans to port. Here's a picture:
Now, the boat seems to sail fine in this condition. I have not noticed any tendency to sail differently on one tack or the other, nor have I noticed the mast failing to rotate or anything like that. Everything seems normal, except for the slight visible lean under rig tension.
From searching these forums, I appear to have three options: A) do nothing. B) try to "bend it back" using jacks or comealongs or any number of other techniques. or C) this is an 1981, unretrofitted metal mast, I could lop it off and put a CompTip on it.
Given the picture, what thoughts do people have? Obviously my short term plan is "do nothing," but I took pictures today and wanted to see if anyone had anything to say on the subject.
Thanks all.
Ian
PostPosted: Mon Jun 09, 2008 3:51 am
That appears to be normal. The mast will bend when you put tension on the downhaul.
To tell if you really have a permanent bend, sight up the sail track when the sail is off the boat.
