It is currently Fri Jun 19, 2026 1:43 am
 Post subject: Weather helm
PostPosted: Tue Jul 01, 2008 6:14 am
Got a question on weather helm and rudder adjustment.
How much does wind speed effect the boats tendency to weather helm. I thought I had my rudders dialed in pretty good as I had little to no rudder pull and good reaction when I released the rudders in 10 knot wind. However last weekend with the winds pushing 18+ knots, thought I’d check things out before I let it rip and I was surprised to have the boat weather helm quite a bit, but not fully and with my 240# ballast, continue sailing..
Now I’m sure, that if I was to fall off or slip while harnessed, the boat would probably flip, but on the off chance…
Anyway, is what I experienced typical and easily corrected with a little less rudder rake or is something else out of whack?
PostPosted: Tue Jul 01, 2008 8:16 am
In my experience, wind speed can be a factor in the amount of weather helm felt. Remember that weather helm is not solely determined by the amount of rudder rake. The helm is really determined by the overall fore-aft balance of the sail plan in relation to the underwater forces generated by the hulls, rudders and daggerboards. So, mast rake and sail trim are quite important.
For example, even when your boat felt balanced on a 10 knot day, if you were to sheet the main in tight and completly luff the jib, you would experience excessive weather helm. The reason being that the center of effort of the sail plan has now shifted aft of the balance point of the hull, so the boat naturally wants to turn into the wind.
So, if your helm is normally balanced, but you felt excessive weather helm on a windy day, it is likely that your overall sailplan was out of balance. Perhaps you eased the jib sheet. Perhaps you under sheeted the main (which can cause the leading edge to luff moving the CE back) - instead travel out and sheet tight. Perhaps your downhaul was too loose - also allowing the CE of the maisail to shift aft. Or maybe you set the boat up with more mast rake.
Or, it is possible that your rudders are raked slightly too far back and the increased power on the windy day caused the helm to be more noticable - you could try raking the rudders under more.
PostPosted: Wed Jul 02, 2008 9:50 am
Thanks for the clarification. Fact was I did have the boat loaded towards the bow, which probably caused it to remain neutral and continue to sail.
