It is currently Sun Aug 02, 2026 1:45 pm
 Post subject: Aft corner castings
PostPosted: Mon Feb 14, 2005 3:33 pm
On my 1973 H-16. There is a 7/32 diameter hole on the starboard and port aft rear castings. Both are on the out board side of the casting what are/were they used for?
Todd
 Post subject: Hole?
PostPosted: Mon Feb 14, 2005 4:59 pm
Hole? They counter sunk too? Sounds like the tramp lacing start point.
Rear lacings start at the rear / outboard corner casting. Pass the 1/4 inch line through that hole and tie a stop knot (knot is inboard, the line exits the hole towards the outboard). The line then runs forward and around the casting to the first tramp grommet.
PostPosted: Mon Feb 14, 2005 10:07 pm
Thanks Matt You are right. I looked it up on the support page, Assyembly manual. This has to be it. The pic on adobe is hard to see. Any one gota pic so I can see how there strung. Mine is not threaded through the castings. It supports everyone fine. I'm sure thier rigged this way for a reason.
Todd
