It is currently Sat Aug 08, 2026 7:31 pm
 Post subject: H17 Centerboard
PostPosted: Wed Jul 23, 2008 1:22 pm
One of my centerboards came apart this last weekend, and it is not repairable. $330.00 seems like lot of cash for a new replacement. Any ideas for a lower cost replacement? Is there a used centerboard out there? Does anyone sail an H17 with no centerboards?
Please Help . . . .
PostPosted: Wed Jul 23, 2008 1:30 pm
I would look on ebay to see if you can find one. (If you do... please let me know. I need a centerboard spring!)
I sailed my boat all of last season with only one centerboard. It seemed to sail just fine, though I'm sure it would have slipped much less with both.
Do you think you might be able to rebuild yours? Can you post pics?
Good luck!
Dave
Truth is treason in the empire of lies.
Campaign for Liberty
 Post subject: centerboards
PostPosted: Sat Jul 26, 2008 5:16 pm
I sailed my 17 sport for years with out using the centerboards often they would get jammed up with sand and small beach pebbles.I found little if no difference. I suppose if you race the boards become important for tacking.
 Post subject: spring
PostPosted: Mon Jul 28, 2008 4:26 am
please call for spring. I have a couple extra. Add one digit to this #-
732-301-3833 when dialing.
w
PostPosted: Wed Aug 06, 2008 12:28 pm
Wow, centerboards are up to $330.00. They were $250.00 a few years back when I bought a second set after reading they were closing out the H17. As it turned out I was able to rebuild my original boards (the hook had broken on one board and the other board partially delaminated). On the broken hook board I used a 6" 3/4 threaded fiberglass rod as the backbone for glassing in a new hook and has worked great for a couple of seasons. On the delamination I injected some resin, then taped and clamped. :)
