It is currently Mon Aug 03, 2026 12:34 pm
PostPosted: Sun Jul 27, 2008 11:18 am
just bought an old 18se. can someone pleeese give me a good general setting for the diamond wires and how to measure if it's right. i plan on 320-440 lbs on the boat 2,3 people recreational sailing, but i also want some performance.
also, i bought new shrouds for it-they are about 3" shorter than the existing ones on it. i talked to a guy who suggested the old ones were way too loose.
general guide on shroud tension?
thanks
oh btw- i saw somewhere that fixing soft decks can be done? i'd like info on that as well
P
peter myers
916 955-1148
PostPosted: Sun Jul 27, 2008 3:26 pm
You need a Hobie 18 performance manual. It was written many years ago, but it will get you in the ballpark for everything. Not written for the SX.
Sails off Angola, NY, Lake Erie.
PostPosted: Sun Jul 27, 2008 3:34 pm
thanks- i've looked online, but not finding the right source for this.
any ideas?
P
peter myers
916 955-1148
PostPosted: Sun Jul 27, 2008 9:55 pm
Here is a nice tuning guide.
http://www.hobievic.org.au/pdfs/Hobie18TuningGuide.pdf
Jeff
Hobie 18 "Blue Jeanne"
PostPosted: Mon Jul 28, 2008 9:48 am
Traditional tuning of the 18 has the diamond wires tighter for heavier crews/lighter wind, diamond wires looser for lighter crews/heavier wind.
The method used in the H18 Performance manual for determining diamond wire tension has you placing marks on the mast (tape) at one-foot intervals starting at the lower diamond wire/rotator bolt and going up 3 feet. The highest point where you can press both wires against the mast is your current setting. A good baseline would probably be somewhere between the one and two foot marks, probably leaning towards the one-foot. Most 18 sailors I see seem to be leaning towards more tension rather than less.
As for mast rake, I haven't measured mine lately, so I can't even give you a reference number there. However, using the standard main blocks (non-low profile) on a new mainsail there is probably 3 to 4" between the blocks when sheeted hard upwind. Sorry I can't be more specific than that. Most important is to have a well balanced helm.
Regarding rig tension, I like to have mine somewhat on the loose side so that the mast can more easily rotate when going downwind. For recreational sailing, it's not a bid deal.
