It is currently Mon Aug 03, 2026 2:12 pm
 Post subject: Shroud length
PostPosted: Fri Aug 29, 2008 10:32 am
I have an '83 with shrouds that need replacement. I'm reluctant to buy new ones from the factory because, as I understand it, the lengths are now different. My current shrouds are 19' 1".
I can't find anywhere that sells the molded covered shroud like I have now, and I really like those. Is there anywhere to get shrouds made for older hobies? I know more mast rake is better, but I like the way mine sails and I don't really want to start messing with that.
PostPosted: Fri Aug 29, 2008 10:48 am
Currrent stock shroud is 18' 11" (soon to be coming as 18' 10 1/4" - 2009 H16)
18' 11" current shroud is just 2" shorter than yours. Unless you are at the top two holes in the current setting ... this is a none issue. Simply adjust the length using the shroud adjusters. 2-3 holes higher using the new shorter shroud. If not enough room... change to 10 hole adjusters.
PostPosted: Tue Jan 20, 2009 2:40 pm
OK guys and gals...
I just got off the phone with Matt. As he had alluded to last year, there are some wire length changes to the 16 for 2009.
And we just figured out that there's no marking on the labels to differentiate between old lengths and new lengths. So because of how parts are stocked at Hobie and probably by most dealers, you could end up with two different lengths when you buy shrouds, bridles or trap wires.
The dimension on the bridle is the most significant change. So if you buy a pair, you might want to make sure they're the same length.
PostPosted: Tue Jan 20, 2009 2:47 pm
Authorized Hobie Dealer
thanks for the heads up Dog. I'm sure we are like yall, we order 20 or 30 at a time and they get put on the H16 shroud hook and back stock bin.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Tue Jan 20, 2009 7:16 pm
Tomhuntington - I got my 19'¼" shrouds from Murrays a few years ago for my 1979 H-16.
www.murrays.com
800-786-7245
I got mine through our Hobie Dealer, but you can contact them direct if you need to. You can get them black or white coated; double swaged.
Good luck!
PostPosted: Wed Jan 21, 2009 8:40 am
O.K I will bite,why the change in shroud length? :?
PostPosted: Wed Jan 21, 2009 9:39 am
Quoting from the dealer website:
[quote]Changes for the 2009 Hobie 16 included wire lengths. Over the years we have accommodated sailors desires for more mast rake. The 2009 model year marks the first significant change since 1995. The new specifications have been well tested and are intended to make the US and Australian new-boat product identical. These new specs will be carried over into the parts department stock of replacement H16 wires, so dealers should be aware of the details.
The most significant of the changes involves bridle wires. These are now longer by 1 1/8â€
PostPosted: Wed Jan 21, 2009 10:52 am
I'm with mmadge, why the change?
07 H16
Sail No. 110387
PostPosted: Wed Jan 21, 2009 11:03 am
Short answer - mast rake.
PostPosted: Wed Jan 21, 2009 11:29 am
I guess I still do not get it as the amount of mast rake has not changed much in the last few years,actually the trend has been a little less rake for more power.
PostPosted: Wed Jan 28, 2009 7:45 am
Can someone post a summary of old and new wire lengths for all standing rigging (bridle, forestay, shroud, traps, and aussie pigtail)? http://www.hca-na.org/ still has the old lengths posted
Bridle: 3' 8 1/4"
Lower Forestay: 17' 6"
Pigtail Forestay: 6"
Shroud: 19' 1/4"
Trap wires: 16' 9 1/8"
Thanks!
PostPosted: Sat Jan 31, 2009 12:58 pm
Listen.
I had the same problem. I just re-rigged my 71 h16. i bought factory shrouds and had a lot of problems at first.
To start off i couldnt even get the mast even close to up. Then i found out i had a shroud as the forestay and the forestay as a shroud. Im retarded.
Fixed that problem and still coouldnt get my mast up. So i bought the 10hole shroud adjusters (vs. the 7hole i had).
After that everything worked good. The mast is raked back alot further now but apparently that is good? Why is that people. I havent had any problems with it. It just kind of looks scary. With my old rigging the mast would pop down all the way into the mast perfectly. Now it goes into the mast base but it doesnt lock into it like it used to with the longer rigging.
1971 H16 (sail #1768)
To all of you on the Hobie Forum... I love you guys!!!
thanks for all the help!
PostPosted: Sat Jan 31, 2009 1:22 pm
Bridle: 3' 8 1/4"
Shroud: 19' 1/4"
Thanks!
Again, quoting from the dealer website:
HOBIE 16 2009 WIRE LENGTHS
Forestay (Aussie) Thimbles both ends (1/8 7/19 wire)
Finished Length - 18 feet 9 3/4 inches
Jib Halyard Pigtail (Aussie) Thimbles both ends (1/8 7/19 wire)
Finished Length - 9 3/4 inches
Bridle Thimble both ends (1/8 1×19 wire)
Finished Length - 3 feet 9 1/2 inches
Shroud Thimble both ends (1/8 1×19 wire)
Finished Length - 18 feet 10 1/4 inches
Trapwire Thimble, stops and handles (3/32 1×19 wire)
Finished Length - 16 feet 7 1/4 inches
PostPosted: Mon Feb 02, 2009 10:57 am
The trend in Worlds has been for more mast rake. This change simply makes it easier to attain max rake. You want to move the mast forward? simply use higher holes in the shroud adjusters.
PostPosted: Mon Feb 02, 2009 6:55 pm
Ok am I missing something here? Mast rake is obtained by the jib halyard. Right? After jib is set the shroud adjustment is only to take up the slack in the shrouds. Right? With my 07 boat I can easily get block to block with the main sheet so why does one need or want longer bridle or shrouds? I do however completely agree with shorter trap wires, when I have my mast raked pretty far aft I can't get enough adjustment to keep a little tension on the shock cord.
07 H16
Sail No. 110387
