It is currently Fri Jun 19, 2026 2:24 pm
 Post subject: Measuring Mast Rake
PostPosted: Sat Aug 30, 2008 8:29 am
After reading Bob Merrick's article regarding H16 setup I finally decided to measure my mast rake. I raised the jib, attached the tack in the center of the adjuster. My shrouds were in the bottom hole and pretty tight. I then raised the main, took the halyard to the left front bridle attach bolt and made a small mark. I then walked to the back of the left hull and pulled the halyard down to the bottom corner of the transom and made another small mark on the halyard. When I measured the distance between the marks I had 23 inches! I then moved the shrouds up 1 hole and tried again with a 21 inch rake measurement. Any less rake and I can't get 2 blocked. Am I doing this measurement correct?
07 H16
Sail No. 110387
PostPosted: Sun Aug 31, 2008 2:43 pm
Yea it sounds like you are doing it correctly. 21 inches sounds like a lot to be just barely getting two blocked unless we are talking about light air.
http://hobiebob.blogspot.com/
 Post subject: Hobie 16 setup article
PostPosted: Mon Sep 01, 2008 6:07 am
Bob- Where is is your Hobie 16 setup article posted? I'm setting up my son's 16 for the big races in IOWA next week. See you there!
Paul Bommersbach
PostPosted: Mon Sep 01, 2008 8:18 am
I'm not sure where it is posted. I put it together a few years ago so I probably need to update it.
PostPosted: Mon Sep 01, 2008 8:47 am
Here it is.
http://www.tedknowlton.com/div12/H16%20Notes.htm
I'll have to make updates this week some time.
PostPosted: Tue Sep 02, 2008 6:26 pm
Thanks Bob!
