It is currently Tue Aug 04, 2026 1:04 pm
PostPosted: Sun Sep 07, 2008 2:14 pm
Hobie Team Member
I was asked if I could help and of course said yes. I have helped out with a few up down control repairs and line replacements. A friend's 2006 Adventure had been vanalized. Both the up/down lever and the steering lever had been "borrowed". It must have been a packrat because in return a broken steering lever had been left.
Inside the hull I was able to tell that everything was still attached to the cranks and both the up and down and the steering were still functional. I found the spring (just large enough to go over the up/down control shaft and the nylon washer for it. I found another spring about 1" diameter by 2" long...nothing else.
Would that be the correct spring for the steering lever and should there be a washer there also?
Thanks for any advice.
Roger
Roger
http://www.aldenofsunapee.com/
Image http://www.NEKF.com/
PostPosted: Sun Sep 07, 2008 4:24 pm
Yes, no
'06 Adventure rudder
up/down
Have fun! 8)
PostPosted: Sun Sep 07, 2008 4:37 pm
Hobie Team Member
Thank you very much. Appreciate the quick feedback. That is exactly what I was hoping to see. I'll grab a couple handles and have the boat back in action.
Thanks again. Roger
Roger
