It is currently Thu Aug 20, 2026 11:01 am
PostPosted: Tue Mar 15, 2005 12:30 pm
I would like to buy a used hobie wave (from 2001) without the trailer. I have a Honda Odyssey with a roof-rack. Can I safely carry the mast on the roof? I am really looking forward to your advise.
Best regards,
Tomek
PostPosted: Tue Mar 15, 2005 12:41 pm
Go For It, I would check out your roof rack weight capacity. Maby cushion the roof where it may rub and some sort of cat trax to get you to the water. Sounds like fun 8)
Todd
The cure for boredom is curiosity. There is no cure for curiosity.
PostPosted: Tue Mar 15, 2005 5:18 pm
I am worried that the mast is going to be too long to carry on a roof rack. Did anyone try this? Any problems with that?
PostPosted: Tue Mar 15, 2005 7:17 pm
Mast is 20' I think your Honda Odyssey is around 17' split the diff or keep the 3' in front to keep a eye on it. I still think its with in reason. Try it if you don't like it get a trailer.
Todd
 Post subject: 2 piece mast
PostPosted: Tue Mar 15, 2005 10:14 pm
Wave masts are two piece. Take it apart and carry the two parts side by side.
PostPosted: Wed Mar 16, 2005 5:52 am
I was hoping this is the case! Thanks for you replies.
Do I need any special tools to split the mast? I am asking because I will drive a bit to get the hobie, I do not want to be caught unprepared...
 Post subject: Car topping
PostPosted: Wed Mar 16, 2005 1:05 pm
I cartop the wave on a VW Passat or a utility trailer. The masts split by pulling them apart, no tools. I put the masts down the middle and the hulls on either side.
PostPosted: Wed Mar 16, 2005 4:43 pm
Thanks! That is all I needed to know.
Tomek
