It is currently Tue Aug 04, 2026 10:07 am
 Post subject: Sidekick questions
PostPosted: Thu Sep 25, 2008 8:21 pm
Can the sidekicks and bars be removed quickly? For example if you wanted to pull up to a dock.
What does AMA stand for?
PostPosted: Thu Sep 25, 2008 8:24 pm
An ama is the outrigger in a trimaran.
Bob Austin
Pensacola, FL
PostPosted: Thu Sep 25, 2008 9:53 pm
I would say you could remove them really quick. It's just a snap of a button (exactly like the paddle connection) and a little tug, and they are off.
Isaac
PostPosted: Fri Sep 26, 2008 4:00 am
http://en.wikipedia.org/wiki/Ama_(sailing)
2010 Hibiscus Adventure Island
PostPosted: Sat Sep 27, 2008 12:34 am
Hawaiian (non-sailing) outrigger canoes have three components. The hull, the ama or floatation device, and the iako or the bars that connect the ama to the hull. Actually there is a fourth component if you include the stubby iako's that are used to transport or store the outrigger canoe.
I do miss outrigger canoe paddling but my shoulder doesn't.
Tim
'09 Adventure, Golden Papaya, Turbo Fins, Large Sailing Rudder, Turquoise Sail, Grey Haired Kayaker, ...
PostPosted: Sun Sep 28, 2008 7:03 am
Thanks for the info guys. Would it be recommended to use sidekicks while out on the ocean but not using the sail? Anyone do that? I can't afford the sail kit right now, but will be going on the ocean, and don't want to capsize.
Also, when paddling, does your paddle hit the sidekick bar? If its mounted right behind your seat it seems like it would.
PostPosted: Mon Sep 29, 2008 8:39 am
Yes, you have to alter a paddle stroke for the SideKick in most mounting positions. They are really great with the MirageDrive boats, but I would paddle with them off and insert once you get to a fish / dive / swim / eat / drink / photo shoot spot if using for a paddle only boat.
PostPosted: Fri Oct 03, 2008 12:58 pm
I have mine behind the seat on the revolution as you noticed in other posts you visited.
I find my paddle does not hit the bar but does hit the nose of the inflatable ama. I have a shorter paddle 210cm that I use if paddling with the sidekick and it takes less adjusted paddle stroke to avoid them. Typically I use a 230cm paddle when not using the sidekick. Pedaling of course is no issue.
Since you have not bought your sail yet you may want to look into the Pacific Coast Sail. I know a guy with one and he says he can reach and tack with it as well as downwind sail. There are always options. Personally I love the Hobie Sail accessory but then I never used a PCS.
PostPosted: Mon Oct 06, 2008 8:40 am
Jorhyne,
I use my sidekicks 100% of the time. I can honestly say that I use my paddle maybe 2% of the time. I bought the sidekicks to stabilize the kayak should I make any sudden movements, and this winter found them invaluable as one time I was out, the surface temp was around 39 degrees. You wouldn't last long in that without the proper gear, and even the fact that it was a small lake, you have to wonder if you could make it to shore. It added a little piece of mind for me.
Oh, and I can't say enough about the sail. I got one for my birthday, and it's been an absolute blast.
Isaac
